주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore 80 Series Washing Machine Lid Switch Replacement
필요한 것
    1. Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: 1 단계, 이미지 2개 중 1개 Kenmore 80 Series Washing Machine Lid Switch Replacement, open console: 1 단계, 이미지 2개 중 2개
      • Control panel console is fastened with two screws. Remove screws, pull bottom end of control panel forward (towards you), swing it upward, rest it in flipped position.
      댓글 쓰기
    2. Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: 2 단계, 이미지 2개 중 1개 Kenmore 80 Series Washing Machine Lid Switch Replacement, unplug switch: 2 단계, 이미지 2개 중 2개
      • Press on tab to release clip/latch. Grip connector, not wires, and pull it off of fixed connector.
      댓글 쓰기
    3. Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 3 단계, 이미지 3개 중 1개 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 3 단계, 이미지 3개 중 2개 Kenmore 80 Series Washing Machine Lid Switch Replacement, open case: 3 단계, 이미지 3개 중 3개
      • Use prise tool to remove two case clips. Pull top of case towards you, rock case (almost whole cabinet: case top, front, left & right) on its bottom front edge as axis, lower front of case until it rests on floor.
      댓글 쓰기
    4. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 4 단계, 이미지 3개 중 1개 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 4 단계, 이미지 3개 중 2개 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove wiring: 4 단계, 이미지 3개 중 3개
      • Case grounding wire is fastened on with one screw, 5/16 (five sixteenths) inch hexagon head. Unhook wires from the guide hooks.
      댓글 쓰기
    5. Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: 5 단계, 이미지 2개 중 1개 Kenmore 80 Series Washing Machine Lid Switch Replacement, remove switch: 5 단계, 이미지 2개 중 2개
      • Switch is fastened on with two screws.
      • Remove connector from case top, squeezing connector's panel mount tabs to free it. when replacing: Face connector with its wedge bump facing frontward.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
unsubstantiated
회원 가입일: 06/07/16
1,192 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 52
지난 30일: 252
전체 시간: 15,422
