주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore Model 110 Clutch Replacement
필요한 것
    1. Kenmore Model 110 Clutch Replacement, Transmission Clutch: 1 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement, Transmission Clutch: 1 단계, 이미지 2개 중 2개
      • Unplug the washing machine.
      • Turn both the hot and cold water supply lines off.
      댓글 쓰기
    2. Kenmore Model 110 Clutch Replacement: 2 단계, 이미지 1개 중 1개
      • Disconnect the supply hoses using channel lock pliers. Use the towel to catch any water that may spill out.
      댓글 쓰기
    3. Kenmore Model 110 Clutch Replacement: 3 단계, 이미지 1개 중 1개
      • Use the channel lock pliers to remove tension on the hose spring clamp and pull the drain line from the washer.
      • Water will come out when hose is disconnected.
      댓글 쓰기
    4. Kenmore Model 110 Clutch Replacement: 4 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 4 단계, 이미지 2개 중 2개
      • Pinch the plastic tabs with the needle nose pliers and push through the metal back panel.
      댓글 쓰기
    5. Kenmore Model 110 Clutch Replacement: 5 단계, 이미지 1개 중 1개
      • Pull up the control panel located on top of the washer machine.
      댓글 쓰기
    6. Kenmore Model 110 Clutch Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the plastic tab on the timer wiring harness connector and pull from the timer.
      댓글 쓰기
    7. Kenmore Model 110 Clutch Replacement: 7 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 7 단계, 이미지 2개 중 2개
      • Disconnect the hose and wiring harness from water level control.
      댓글 쓰기
    8. Kenmore Model 110 Clutch Replacement: 8 단계, 이미지 3개 중 1개 Kenmore Model 110 Clutch Replacement: 8 단계, 이미지 3개 중 2개 Kenmore Model 110 Clutch Replacement: 8 단계, 이미지 3개 중 3개
      • Push tab and remove the connector that is next to the water level control on the inside of the control panel.
      • Pull the connector from the door safety switch located on the main body of the washing machine top.
      • Disconnect the green wire ground point inside the control panel with the ratchet and a 1/4 inch socket.
      댓글 쓰기
    9. Kenmore Model 110 Clutch Replacement: 9 단계, 이미지 1개 중 1개
      • Use the flat head screwdriver to pry out clips on left and right side on top of the machine where the control panel was.
      댓글 쓰기
    10. Kenmore Model 110 Clutch Replacement: 10 단계, 이미지 3개 중 1개 Kenmore Model 110 Clutch Replacement: 10 단계, 이미지 3개 중 2개 Kenmore Model 110 Clutch Replacement: 10 단계, 이미지 3개 중 3개
      • Pull the hood gently from the front to separate from the base, leaving the tub, motor, and transmission exposed.
      • Carefully tilt the washer and set it on the back panel
      댓글 쓰기
    11. Kenmore Model 110 Clutch Replacement: 11 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the pump retaining clips.
      • Leave the pump hoses attached and move the pump aside.
      댓글 쓰기
    12. Kenmore Model 110 Clutch Replacement: 12 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 12 단계, 이미지 2개 중 2개
      • Lift the tab and remove the motor wiring harness connector.
      • Remove the plastic clip from the transmission housing.
      댓글 쓰기
    13. Kenmore Model 110 Clutch Replacement: 13 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the motor retaining clip screws with the ratchet and a 1/4 inch socket.
      • Use the flat head screw driver to pry retaining clips off of motor.
      댓글 쓰기
    14. Kenmore Model 110 Clutch Replacement: 14 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 14 단계, 이미지 2개 중 2개
      • Separate the motor from the transmission.
      • Be sure to check the rubber motor coupling while it is apart. The motor and the transmission will have a plastic piece with three prongs that fit into the rubber coupling. Check to make sure plastic prongs have not broken and the rubber coupling is not cracked.
      • If the motor coupling is cracked or broken it will need to be replaced.
      댓글 쓰기
    15. Kenmore Model 110 Clutch Replacement: 15 단계, 이미지 3개 중 1개 Kenmore Model 110 Clutch Replacement: 15 단계, 이미지 3개 중 2개 Kenmore Model 110 Clutch Replacement: 15 단계, 이미지 3개 중 3개
      • Inside the wash tank, use the flat head screw driver to pop cap off of the agitator.
      • Remove the transmission shaft nut with the ratchet and a 7/16 inch socket.
      • Remove the agitator by pulling it from the transmission shaft.
      댓글 쓰기
    16. Kenmore Model 110 Clutch Replacement: 16 단계, 이미지 2개 중 1개 Kenmore Model 110 Clutch Replacement: 16 단계, 이미지 2개 중 2개
      • On the bottom of the machine, remove the 3 bolts that hold the transmission in place with the ratchet and a 3/8 inch socket.
      • Gently pull the transmission out of the washer.
      댓글 쓰기
    17. Kenmore Model 110 Clutch Replacement: 17 단계, 이미지 3개 중 1개 Kenmore Model 110 Clutch Replacement: 17 단계, 이미지 3개 중 2개 Kenmore Model 110 Clutch Replacement: 17 단계, 이미지 3개 중 3개
      • Remove the metal washer from the transmission shaft.
      • Pry the retaining clip from the transmission shaft with the flat head screw driver.
      • Pry the spring clip from the clutch with the flat head screw driver.
      댓글 쓰기
    18. Kenmore Model 110 Clutch Replacement: 18 단계, 이미지 1개 중 1개
      • Remove the clutch.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jonathan Beach
회원 가입일: 01/30/18
458 평판
안내서 1개를 작성함
3가이드 댓글
Nice tutorial! Thank you!
jdickes427 - 답글 공유
My Kenmore washer is as same as this one, but now the agitator works, but it does not spin. So far I reached step 14, did not find anything wrong, which parts could be the problem? Clutch? Thanks
Harry Song - 답글 공유
Did you find out what was wrong with it? Mine is doing the same thing.
Jacob - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 49
지난 30일: 190
전체 시간: 19,092
