주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keurig K55 Lid Spring Replacement
필요한 것
    1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: 1 단계, 이미지 3개 중 1개 Keurig K55 Lid Spring Replacement, Secondary Water Pump: 1 단계, 이미지 3개 중 2개 Keurig K55 Lid Spring Replacement, Secondary Water Pump: 1 단계, 이미지 3개 중 3개
      • Lift the silver handle up.
      • Locate the screw and washer holding the handle in place on each side.
      • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
      댓글 쓰기
    2. Keurig K55 Lid Spring Replacement: 2 단계, 이미지 2개 중 1개 Keurig K55 Lid Spring Replacement: 2 단계, 이미지 2개 중 2개
      • Grab the handle and pull it upward and toward the rear of the device.
      • Lift the lid to the fully open position.
      • Remove the two 11mm Phillips screws located on the upper part of the device.
      • Be careful removing the screws; the needle here may be sharp.
      댓글 쓰기
    3. Keurig K55 Lid Spring Replacement: 3 단계, 이미지 3개 중 1개 Keurig K55 Lid Spring Replacement: 3 단계, 이미지 3개 중 2개 Keurig K55 Lid Spring Replacement: 3 단계, 이미지 3개 중 3개
      • Lower the lid to just before its closing position.
      • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
      • Gently pull the top cover upward and toward the front of the device to remove it.
      댓글 쓰기
    4. Keurig K55 Lid Spring Replacement: 4 단계, 이미지 3개 중 1개 Keurig K55 Lid Spring Replacement: 4 단계, 이미지 3개 중 2개 Keurig K55 Lid Spring Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the two 11mm Phillips head screws securing the water pump.
      • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
      • Pull the other line from the water pump.
      댓글 쓰기
    1. Keurig K55 Lid Spring Replacement, Lid Spring: 5 단계, 이미지 2개 중 1개 Keurig K55 Lid Spring Replacement, Lid Spring: 5 단계, 이미지 2개 중 2개
      • Pull the spring off the front hook using two fingers.
      • The spring has a lot of tension, so grip the spring end tightly.
      댓글 쓰기
    2. Keurig K55 Lid Spring Replacement: 6 단계, 이미지 2개 중 1개 Keurig K55 Lid Spring Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the spring off the other hook.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
William O'Brien
회원 가입일: 01/23/18
500 평판
안내서 4개를 작성함
Cal Poly, Team S1-G3, Livingston Winter 2018 Cal Poly, Team S1-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S1G3
4 회원들
안내서 30개를 작성함
2가이드 댓글
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - 답글 공유
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Joe K - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 49
전체 시간: 2,601
