주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keurig Mini B-31 Top Needle Replacement
필요한 것
    1. Keurig Mini B-31 Top Needle Replacement, K-cup holder: 1 단계, 이미지 1개 중 1개
      • Lift up the handle of the Keurig Mini.
      댓글 쓰기
    2. Keurig Mini B-31 Top Needle Replacement: 2 단계, 이미지 2개 중 1개 Keurig Mini B-31 Top Needle Replacement: 2 단계, 이미지 2개 중 2개
      • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
      • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
      댓글 쓰기
    3. Keurig Mini B-31 Top Needle Replacement: 3 단계, 이미지 2개 중 1개 Keurig Mini B-31 Top Needle Replacement: 3 단계, 이미지 2개 중 2개
      • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
      댓글 쓰기
    4. Keurig Mini B-31 Top Needle Replacement: 4 단계, 이미지 1개 중 1개
      • Pull the K-cup holder straight out.
      댓글 쓰기
    1. Keurig Mini B-31 Top Needle Replacement, Top: 5 단계, 이미지 3개 중 1개 Keurig Mini B-31 Top Needle Replacement, Top: 5 단계, 이미지 3개 중 2개 Keurig Mini B-31 Top Needle Replacement, Top: 5 단계, 이미지 3개 중 3개
      • Open the top lid of the Keurig.
      • Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
      댓글 쓰기
    2. Keurig Mini B-31 Top Needle Replacement: 6 단계, 이미지 1개 중 1개
      • Lay the Keurig on its back with the water reservoir pointing away from you.
      댓글 쓰기
    3. Keurig Mini B-31 Top Needle Replacement: 7 단계, 이미지 1개 중 1개
      • Avoid the top needle as it may puncture your hand.
      • Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
      댓글 쓰기
    4. Keurig Mini B-31 Top Needle Replacement: 8 단계, 이미지 1개 중 1개
      • Set the Keurig in an upright position with the front side facing you.
      • Pull the cover off the top of the Keurig. It should come off easily with little force.
      댓글 쓰기
    5. Keurig Mini B-31 Top Needle Replacement: 9 단계, 이미지 1개 중 1개
      • Firmly grasp the hose and pull it off of the plastic nozzle.
      댓글 쓰기
    1. Keurig Mini B-31 Top Needle Replacement, Top Needle: 10 단계, 이미지 1개 중 1개
      • Unscrew the two 9 mm #1 Philips screws at the top of the device.
      댓글 쓰기
    2. Keurig Mini B-31 Top Needle Replacement: 11 단계, 이미지 1개 중 1개
      • Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Adriance
회원 가입일: 01/14/14
1,914 평판
안내서 7개를 작성함
Cal Poly, Team 17-1, Forte Winter 2014 Cal Poly, Team 17-1, Forte Winter 2014 회원
CPSU-FORTE-W14S17G1
5 회원들
안내서 31개를 작성함
1가이드 댓글
This is great but where do I buy the top needle replacement part?
Jen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 40
전체 시간: 18,111
