주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keyboard Keyswitch Replacement How To
    1. Keyboard Keyswitch Replacement How To, Step 1: Grab the tool shown in the image: 1 단계, 이미지 1개 중 1개
      • First you are gonna want to grab a keycap puller/remover.
      댓글 쓰기
      • Do what the video depicts. Pull of the keycap with the keycap remover
      댓글 쓰기
    2. Keyboard Keyswitch Replacement How To, Step 3: Grab the Other Tool: 3 단계, 이미지 1개 중 1개
      • Grab the keyswitch remover shown in the image.
      댓글 쓰기
    3. Keyboard Keyswitch Replacement How To, Step 4: Locate the Grooves: 4 단계, 이미지 1개 중 1개
      • There are 2 grooves on the sides of the keyswitch. Your keyswitch will still be in the keyboard, but I took mine out to show them closer.
      댓글 쓰기
      • Grab the 2 grooves with the keyswitch remover like I did. It is important you pull straight up otherwise you could damage our break the pin, which is bad. It may require some force.
      댓글 쓰기
    4. Keyboard Keyswitch Replacement How To, Step 6: Grab New Keyswitch: 6 단계, 이미지 1개 중 1개
      • Grab your new keyswitch, you don't need the old one anymore. Now first you want to make sure you have the proper amount of pins. For example my keyboard has two and the keyswitch also has 2.
      댓글 쓰기
      • Grab your new keyswitch and line up the pins with the holes in the keyboard. Press firmly and it should pop into place. It may require a bit of force, but you could have also lined up the pins wrong so always double check. It should not wiggle at all, it should be firm and sending signals.
      댓글 쓰기
    5. Keyboard Keyswitch Replacement How To, Step 8: Check Keycap: 8 단계, 이미지 1개 중 1개
      • The keycap and keyswitch both have the cross hole. They should line up when installing.
      댓글 쓰기
      • The keycap should just pop on and it should fit. Make sure that its facing the right way and in the correct position. Now you are finished! it should click, sound and send signals like all the other ones (considering you are replacing all of them, if not it still should send signals and sound and click like the other new ones.)
      댓글 쓰기
결론
Just rinse and repeat for all the keys you need replaced!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
SemiNormalHuman
회원 가입일: 04/16/26
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 28
지난 30일: 41
전체 시간: 97
