주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Keychron K10 Max Wireless Mechanical Key Switch Replacement
필요한 것
  1. Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 1 단계, 이미지 3개 중 1개 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 1 단계, 이미지 3개 중 2개 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 1 단계, 이미지 3개 중 3개
    • Lay the keyboard face down on the workspace.
    • Use a 2.5 mm hex screwdriver to remove the eight 4.5 mm screws from the back case.
    • Carefully separate the front frame from the keyboard and set it aside.
    • There is a clear shield that sits right above the arrow keys. This shield is to diffuse the LEDs from the keyboard, and it can fall out easily. Just remember to put it back if it does when reassembly.
    댓글 쓰기
  2. Keychron K10 Max Wireless Mechanical Key Switch Replacement: 2 단계, 이미지 2개 중 1개 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the keycap puller over the keycap until it grips underneath.
    • Pull straight upward to remove the keycap.
    • Sometimes the mechanical switch itself comes with the keycap. Just remove the switch from the button and reinstall the switch.
    댓글 쓰기
  3. Keychron K10 Max Wireless Mechanical Key Switch Replacement, Mechanical Key Switch: 3 단계, 이미지 2개 중 1개 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Mechanical Key Switch: 3 단계, 이미지 2개 중 2개
    • Place the switch puller around the two small tabs on the front and back of the switch.
    • Squeeze the switch puller to release the tabs, then pull straight upward to remove the switch.
    • The photos show red mechanical switches, but your keyboard may have a different switch color. The removal process is the same for this style of hot-swappable mechanical switch.
    댓글 쓰기
  4. Keychron K10 Max Wireless Mechanical Key Switch Replacement: 4 단계, 이미지 3개 중 1개 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 4 단계, 이미지 3개 중 2개 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 4 단계, 이미지 3개 중 3개
    • The replacement switch is oriented to fit only one way.
    • Align the copper pins on the bottom of the switch with the socket.
    • Make sure the copper pins are aligned before pressing the switch into place. Installing the switch in the wrong orientation can bend or break the pins.
    • Press the switch straight down until it clicks into place.
    • The switch should sit flush with the surrounding switches and the keyboard frame.
    댓글 쓰기
결론
Once the switch is installed, you can reassemble your device back to normal. To reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Richard Witkowski
회원 가입일: 03/23/26
595 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 38
전체 시간: 147
