주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle 2 Screen Replacement
필요한 것
  1. Kindle 2 Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 Kindle 2 Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 Kindle 2 Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Lay the Kindle face down on a soft cloth to protect its screen.
    • Wedge the plastic opening tool in the small opening between the grey plastic and the metal casing.
    • Move the plastic opening tool across the opening while pressing down to separate the grey plastic from the metal casing.
    • Slide the gray plastic top piece away from the Kindle's metal casing.
    • Once the gray plastic top piece is detached from the metal back cover, remove it.
    댓글 쓰기
  2. Kindle 2 Screen Replacement: 2 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws from the metal casing.
    댓글 쓰기
  3. Kindle 2 Screen Replacement: 3 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to push down and pry towards the metal casing to release each of the three clips that hold the metal case in place.
    • Remove the metal casing.
    • The volume control button rests in a slot on the side of the Kindle. When the metal casing is removed, the volume control button may fall out. When reassembling, place the volume control button back into its slot.
    댓글 쓰기
  4. Kindle 2 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the battery in place.
    • The battery should be removed before continuing with the rest of this guide to prevent harm to you and the device.
    댓글 쓰기
  5. Kindle 2 Screen Replacement: 5 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Pry upward under the black tab with the spudger to dislodge the battery.
    • Use your fingers to lift the battery out of the device.
    댓글 쓰기
  6. Kindle 2 Screen Replacement, Wireless Card: 6 단계, 이미지 1개 중 1개
    • Rotate the Kindle 180 degrees. Locate the wireless card with the AnyData logo on the top left and the FCC symbol on the right.
    • Use a Phillips #00 screwdriver to remove the two 2mm screws from the wireless card.
    댓글 쓰기
  7. Kindle 2 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to wedge underneath the connection and gently pop off the wire cap.
    댓글 쓰기
  8. Kindle 2 Screen Replacement: 8 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use your fingers to lift the left end of the wireless card.
    • Pull the card out of the slot.
    댓글 쓰기
  9. Kindle 2 Screen Replacement, Motherboard: 9 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement, Motherboard: 9 단계, 이미지 2개 중 2개
    • Remove 16 screws from the midframe.
    댓글 쓰기
  10. Kindle 2 Screen Replacement: 10 단계, 이미지 3개 중 1개 Kindle 2 Screen Replacement: 10 단계, 이미지 3개 중 2개 Kindle 2 Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
    • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
    댓글 쓰기
  11. Kindle 2 Screen Replacement: 11 단계, 이미지 3개 중 1개 Kindle 2 Screen Replacement: 11 단계, 이미지 3개 중 2개 Kindle 2 Screen Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Wedge the opening tool underneath the plastic ribbon and gently pull up to lift the brown connector flap.
    • Squeeze the plastic ribbon gently with the tweezers and pull away from the connector to remove it.
    댓글 쓰기
  12. Kindle 2 Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Locate the next brown connector three inches to the right of the previous connector and repeat Step 10 to remove the plastic ribbon.
    댓글 쓰기
  13. Kindle 2 Screen Replacement: 13 단계, 이미지 2개 중 1개 Kindle 2 Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Rotate the device 180 degrees and locate a smaller brown connector on the left side of the device.
    • Repeat Step 10.
    댓글 쓰기
  14. Kindle 2 Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Push your finger down on the last plastic ribbon.
    • Slide your finger away from the connector to remove the last ribbon.
    댓글 쓰기
  15. Kindle 2 Screen Replacement: 15 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws from the motherboard located around the LAB126 logo.
    댓글 쓰기
  16. Kindle 2 Screen Replacement: 16 단계, 이미지 1개 중 1개
    • Grab the bottom corner of the motherboard and safely remove it from the Kindle.
    댓글 쓰기
  17. Kindle 2 Screen Replacement, Screen: 17 단계, 이미지 1개 중 1개
    • Flip the motherboard over so the screen is facing up.
    • Using your fingers, gently pull off the plastic header bar located at the top of the screen attached to the motherboard.
    댓글 쓰기
  18. Kindle 2 Screen Replacement: 18 단계, 이미지 3개 중 1개 Kindle 2 Screen Replacement: 18 단계, 이미지 3개 중 2개 Kindle 2 Screen Replacement: 18 단계, 이미지 3개 중 3개
    • The screen is attached to the motherboard with double sided tape.
    • Pry underneath all four sides of the device with the plastic opening tool to remove the screen from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Dayna Scott
회원 가입일: 04/16/13
985 평판
안내서 5개를 작성함
Cal Poly, Team 12-32, Amido Spring 2013 Cal Poly, Team 12-32, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G32
4 회원들
안내서 14개를 작성함
7가이드 댓글
Great guide!
My replacement screen came with a spudger like the one shown, but it was pretty mangled by the time I got the back off. I had much better luck with another spudger shaped like a guitar pick.
Yeah, the step to remove the inner plastic protector is missing. It is pretty obvious that it needs to happen, but it would be good to include in the guide.
The ribbon for the screen needs to be pushed in further than the other ribbons, and took a bit of wiggling. FYI for others attempting this!
Hannah - 답글 공유
I followed this guide, but the screen is still on the "Amazon Kindle" screen that was on the replacement when it came in the mail. I opened it to ensure the ribbons are all in place. It's fully charged (green light) and the computer can see it as a hard drive. Calibre can also see all the books are still in place. Any ideas what connection I need to recheck to get the replacement screen working? I'd love to get my old Kindle 2 back in business!
tanderson92 - 답글 공유
Answering my own question in case it helps anyone. It turns out the ribbon for the screen (the last one removed in Step 14) wasn't far enough in the connector. I was trying it with the line about even with the "39" on the board, which wasn't far enough. After the eBay seller kindly gave me some tips, I was able to manhandle the ribbon closer to the connector, and now the screen works great!
tanderson92 - 답글 공유
Where can I get one of those replacement screens?
Andie - 답글 공유
In order to be pre-prepared, (I'm pretty sure the double-sided tape holding the screen to the motherboard will need replacement after years of service) is the tape of the fairly thick foam variety or the much thinner plastic ribbon style?
Richard Herndon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 73
전체 시간: 24,184
