주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle 4 Screen Replacement
필요한 것
    1. Kindle 4  Screen  Replacement, Remove the back cover: 1 단계, 이미지 2개 중 1개 Kindle 4  Screen  Replacement, Remove the back cover: 1 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the back of the kindle.
      • The back is glued in the middle to the stainless steel battery cover with double sided tape, and attached with 2 tabs at each end. The top and bottom tabs slide into the frame, so if you pull too hard they might break. Once you have unclipped, use a hot air gun on moderate temperature to help release the double sided adhesive.
      • Watch out for static electricity, it might destroy your device. Discharge before you start by holding a radiator or using a strap.
      • Start with opening the back at the sides. Push your knife or tweezers in a bit deeper at the middle and twist them to push the glued cover part from the frame. Don't do this near the side buttons as you might cut the buttons' ribbon cable.
      • See this video from 0:33 to 2:00. Do not follow it any further as you don't need every step from this video to replace the screen!
      댓글 쓰기
    2. Kindle 4  Screen  Replacement: 2 단계, 이미지 1개 중 1개
      • pull the black tab of the battery connector up and then pull out the cable carefully
      댓글 쓰기
    3. Kindle 4  Screen  Replacement, Disconnect screen: 3 단계, 이미지 1개 중 1개
      • Now the back side is open, disconnect the screen cable from the motherboard as is done in this video from 3:14 until 3:21. Again do not follow the next steps from the video as we don't need them to replace the screen.
      댓글 쓰기
    4. Kindle 4  Screen  Replacement, Remove front cover: 4 단계, 이미지 1개 중 1개
      • Remove the front cover as is shown in this video from 4:11 until 4:48
      • Again do not follow the video any further as we do not need these steps to replace the screen
      댓글 쓰기
    5. Kindle 4  Screen  Replacement, Remove old screen: 5 단계, 이미지 2개 중 1개 Kindle 4  Screen  Replacement, Remove old screen: 5 단계, 이미지 2개 중 2개
      • The screen is glued to the bezel over the entire surface of the screen, so inevitably the screen will be broken in pieces when removing it from the bezel.
      • Start from the sides and break of the screen piece by piece by pushing tweezers between the bezel and the screen. The glue loosens easier if you warm up the screen with a blow dryer.
      댓글 쓰기
    6. Kindle 4  Screen  Replacement, Remove the glue: 6 단계, 이미지 1개 중 1개
      • This is the most tedious step. Remove the glue and fine bits of glass sticking to the bezel. Not all glue has to be removed, but the glass has to be gone. You can scrape off the glue with a knife (razor blade is the most convenient, but a regular knife works as well) or use the help of some solvents.
      • The picture shows the bezel before glue removal. I forgot to take one after.
      댓글 쓰기
    7. Kindle 4  Screen  Replacement, insert the new screen: 7 단계, 이미지 3개 중 1개 Kindle 4  Screen  Replacement, insert the new screen: 7 단계, 이미지 3개 중 2개 Kindle 4  Screen  Replacement, insert the new screen: 7 단계, 이미지 3개 중 3개
      • Put the new screen in place.
      • Make sure the connector sticks through the bezel.
      • Connect the connector to the motherboard
      • Test the connection by turning the device on
      댓글 쓰기
      • Clip the front and back cover back in.
      댓글 쓰기
결론
This guide will help you to disassemble your device, take out the old screen, replace it by a new and reassemble your device.
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Francis Santens
회원 가입일: 11/07/16
1,067 평판
안내서 2개를 작성함
17가이드 댓글
Mine has the same issue but the replacement screens are so expensive it is not interesting to repair it :-(
Thanks anyway for the guide ;-)
weax - 답글 공유
Mine was around €20 incl shipping: https://nl.aliexpress.com/item/LCD-Displ...
Francis Santens - 답글 공유
having a really hard time with breaking the screen, any advice beyond what you've posted? what tools do you recommend?
melissa.cm.kong - 답글 공유
I just used a kitchen knife and a blow dryer. It is definitely the most time consuming part. Good luck!
I've bought ED060SCN LF instead of ED060SCF LF will it work? it is for kindle 5 but seller wrote it is good for Kindle 4 too... might be a good idea to uplug old screen and plug new in just for powering up before start removing the old imho, I will check..
FotoAmg AmgFoto - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 95
지난 30일: 303
전체 시간: 46,660
