주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle 7th Generation Back Panel Replacement
필요한 것
    1. Kindle 7th Generation Back Panel Replacement, Front Panel: 1 단계, 이미지 2개 중 1개 Kindle 7th Generation Back Panel Replacement, Front Panel: 1 단계, 이미지 2개 중 2개
      • Power off your Kindle before beginning disassembly.
      • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
      • Run the tool along the seams to pry open the front panel.
      댓글 쓰기
    2. Kindle 7th Generation Back Panel Replacement: 2 단계, 이미지 1개 중 1개
      • Peel the front panel off to remove it from the Kindle.
      • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
      • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
      • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
      댓글 쓰기
    1. Kindle 7th Generation Back Panel Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Kindle 7th Generation Back Panel Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
      • Remove the ten 5.0 mm T5 Torx screws.
      • A magnetized screw mat can help you keep track of your screws.
      댓글 쓰기
    2. Kindle 7th Generation Back Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Working evenly along the corners and edges, separate the internal contents from the back panel.
      • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Abby Roulier
회원 가입일: 02/08/15
1,167 평판
안내서 3개를 작성함
Cal Poly, Team 6-28, Amido Winter 2015 Cal Poly, Team 6-28, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G28
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 32
지난 30일: 89
전체 시간: 6,361
