주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire Back Case Replacement
필요한 것
  1. Kindle Fire Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 1개 Kindle Fire Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 2개 Kindle Fire Back Case Replacement, Back Case: 1 단계, 이미지 3개 중 3개
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    댓글 쓰기
  2. Kindle Fire Back Case Replacement: 2 단계, 이미지 1개 중 1개
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Phillip Takahashi
회원 가입일: 08/22/11
87,893 평판
안내서 87개를 작성함
3가이드 댓글
Simple to follow instructions .
Eric Rester - 답글 공유
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - 답글 공유
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 80
전체 시간: 17,490
