주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire HD 2013 Screen Replacement
필요한 것
    1. Kindle Fire HD 2013 Screen Replacement, Screen: 1 단계, 이미지 3개 중 1개 Kindle Fire HD 2013 Screen Replacement, Screen: 1 단계, 이미지 3개 중 2개 Kindle Fire HD 2013 Screen Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • Open up the device by using a plastic opening tool in order to avoid damaging the device.
      • To do so, find the seam along the outer edge of the device and use the plastic tool to pry the back panel up. Doing so may take some force and patience.
      댓글 쓰기
    2. Kindle Fire HD 2013 Screen Replacement: 2 단계, 이미지 2개 중 1개 Kindle Fire HD 2013 Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Before we can reach the screen, we must remove the plate that holds the rest of the components.
      • To do so, locate and remove the (10) 3mm T4 Torx screws highlighted.
      • There are also two ribbons connected the main device to the screen. To remove these, follow the ribbon to where they connect and use the spudger or a finger nail to lift the tab. Once open, gently pull the ribbon out.
      댓글 쓰기
    3. Kindle Fire HD 2013 Screen Replacement: 3 단계, 이미지 1개 중 1개
      • After locating the USB port at the top of the device, remove the (2) 3mm T4 Torx screws.
      댓글 쓰기
    4. Kindle Fire HD 2013 Screen Replacement: 4 단계, 이미지 1개 중 1개
      • After locating the Aux port at the bottom of the device, remove the (2) 3mm T4 Torx screws.
      댓글 쓰기
    5. Kindle Fire HD 2013 Screen Replacement: 5 단계, 이미지 3개 중 1개 Kindle Fire HD 2013 Screen Replacement: 5 단계, 이미지 3개 중 2개 Kindle Fire HD 2013 Screen Replacement: 5 단계, 이미지 3개 중 3개
      • Once the screws and ribbons are removed, use the nylon spudger to gently remove the plate holding the rest of the components and set to the side.
      • Once the plate has been removed, located the (4) 3mm T4 Torx screws and remove them.
      • There is a single ribbon here that has to be removed as well. Follow the ribbon to where it connects. Gently lift the tab using the spudger or a fingernail. Once the tab is open, gently pull the ribbon out and away.
      댓글 쓰기
    6. Kindle Fire HD 2013 Screen Replacement: 6 단계, 이미지 2개 중 1개 Kindle Fire HD 2013 Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Once the ribbon and screws are removed, pick the part up and tilt it into your other hand. The touch screen component and the clear cover should now be disconnected completely.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
aaa
회원 가입일: 10/06/16
745 평판
안내서 5개를 작성함
USF Tampa, Team 2-3, Sullivan Fall 2016 USF Tampa, Team 2-3, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G3
4 회원들
안내서 31개를 작성함
1가이드 댓글
HI CAN U HELP WHERE TO BUY THE LCD AND DIGITIZER FOR THIS MODEL THANK YOU PLS EMAIL me
robert.vanderas@gmail.com
robert vanderas - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 51
전체 시간: 5,349
