주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire HD 6 Battery Replacement
필요한 것
    1. Kindle Fire HD 6 Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Place the device face down on a clean cloth or another smooth surface.
      • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
      • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
      • Maneuver the tool around the device until the back unclips from the front panel.
      댓글 쓰기
    2. Kindle Fire HD 6 Battery Replacement: 2 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Carefully separate the back panel from the rest of the device internals.
      댓글 쓰기
    1. Kindle Fire HD 6 Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      iOpener
      $14.95
      • Gently pry the battery free from the adhesive holding it in place.
      • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
      • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
      • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
      댓글 쓰기
    2. Kindle Fire HD 6 Battery Replacement: 4 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
      • Remove the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cassandra Beck
회원 가입일: 01/13/15
885 평판
안내서 5개를 작성함
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 회원
CPSU-FORTE-W15S70G4
4 회원들
안내서 12개를 작성함
2가이드 댓글
Thank you it worked for me.
A bit nervous breaking it down, once I got the back plate off it was very simple, unplugged the battery, reconnected put it back together fired it up , great advice.
Thanks again
Regards
Terry
terry pils - 답글 공유
The battery removal step did not sufficiently warn about how hard the adhesive used for the battery was, and using the spudger ended up piercing the battery when I tried to pry the battery off.
Sean Collins - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 88
전체 시간: 9,606
