주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Fire HD 6 Motherboard Replacement
필요한 것
    1. Kindle Fire HD 6 Motherboard Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Place the device face down on a clean cloth or another smooth surface.
      • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
      • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
      • Maneuver the tool around the device until the back unclips from the front panel.
      댓글 쓰기
    2. Kindle Fire HD 6 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Carefully separate the back panel from the rest of the device internals.
      댓글 쓰기
    1. Kindle Fire HD 6 Motherboard Replacement, Rear Facing Camera: 3 단계, 이미지 1개 중 1개
      • Unscrew the two 3.5mm T5 Torx Screws from the top of the camera.
      댓글 쓰기
    2. Kindle Fire HD 6 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Kindle Fire HD 6 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
      • Be careful not to damage the camera lens as you remove the camera.
      • Gently pull the camera up and out of the device. As you pull, unclip the black and white connector with orange tape by popping it off at its base.
      댓글 쓰기
    1. Kindle Fire HD 6 Motherboard Replacement, Speaker: 5 단계, 이미지 1개 중 1개
      • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
      댓글 쓰기
    2. Kindle Fire HD 6 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
      댓글 쓰기
    3. Kindle Fire HD 6 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Lift the speaker out of the device.
      댓글 쓰기
    1. Kindle Fire HD 6 Motherboard Replacement, Battery: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      iOpener
      $14.95
      • Gently pry the battery free from the adhesive holding it in place.
      • Take care not to pierce or rupture the battery, which can release dangerous chemicals.
      • If you're having trouble working the battery free, warm it up with an iOpener or hair dryer to soften the adhesive, and then slide a credit card behind the battery to break up the adhesive.
      • Be careful not to yank the battery out—you'll need to disconnect a connector before removing the battery completely.
      댓글 쓰기
    2. Kindle Fire HD 6 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the multi-colored connector that joins the battery and the motherboard by pulling it straight up.
      • Remove the battery.
      댓글 쓰기
    1. Kindle Fire HD 6 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement, Motherboard: 10 단계, 이미지 2개 중 2개
      • Zero insertion force connectors can break easily. Before performing this step, read the iFixit Guide to Recognizing and Disconnecting Cable Connectors to find out how to safely remove them.
      • Use the tip of the spudger to disconnect the two zero insertion force connectors on the bottom and top of the motherboard.
      • The first connector is attached to an orange tape, and is located in the bottom-right corner of the motherboard. Remove this connector.
      • The second connector is long and thin, and is located at the top of the motherboard, a bit to the right of center. Remove this connector.
      댓글 쓰기
    2. Kindle Fire HD 6 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
      • Disconnect the black and white connector at the very top-center of the motherboard by unclipping it using the flat side of the spudger.
      댓글 쓰기
    3. Kindle Fire HD 6 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
      • Unscrew the ten 3.5mm T5 Torx screws around the edge of the motherboard.
      댓글 쓰기
    4. Kindle Fire HD 6 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Kindle Fire HD 6 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
      • Starting from the bottom, lift the motherboard out of the device. You will have to push the motherboard about two millimeters toward the top of the device to unhook the top edge.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Cassandra Beck
회원 가입일: 01/13/15
885 평판
안내서 5개를 작성함
Cal Poly, Team 70-4, Forte Winter 2015 Cal Poly, Team 70-4, Forte Winter 2015 회원
CPSU-FORTE-W15S70G4
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 38
전체 시간: 3,492
