주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Paperwhite 2nd Generation Power Button Replacement
필요한 것
    1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: 1 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: 1 단계, 이미지 2개 중 2개
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      댓글 쓰기
    2. Kindle Paperwhite 2nd Generation Power Button Replacement: 2 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Power Button Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      댓글 쓰기
    3. Kindle Paperwhite 2nd Generation Power Button Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully lift and remove the mid-frame.
      댓글 쓰기
    4. Kindle Paperwhite 2nd Generation Power Button Replacement: 4 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Power Button Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tyler Davis
회원 가입일: 09/15/16
2,007 평판
안내서 5개를 작성함
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 31개를 작성함
5가이드 댓글
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - 답글 공유
Seconding this: where exactly can I purchase the button?
Oren Leifer - 답글 공유
Same for me…..where can I buy this button?
Rob Hoenstok - 답글 공유
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - 답글 공유
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 123
전체 시간: 6,343
