주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Paperwhite 2nd Generation Screen Replacement
필요한 것
    1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      댓글 쓰기
    2. Kindle Paperwhite 2nd Generation Screen Replacement: 2 단계, 이미지 2개 중 1개 Kindle Paperwhite 2nd Generation Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      댓글 쓰기
    3. Kindle Paperwhite 2nd Generation Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully lift and remove the mid-frame.
      댓글 쓰기
    4. Kindle Paperwhite 2nd Generation Screen Replacement: 4 단계, 이미지 1개 중 1개
      • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Davis
회원 가입일: 09/15/16
2,007 평판
안내서 5개를 작성함
USF Tampa, Team 11-2, Blackwell Fall 2016 USF Tampa, Team 11-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G2
4 회원들
안내서 31개를 작성함
3가이드 댓글
My opening tool is orange. Will this still work for me?
FoxRunTime - 답글 공유
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - 답글 공유
Did this work Liam?
Ben Lowdon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 32
지난 30일: 174
전체 시간: 15,623
