주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement
필요한 것
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: 1 단계, 이미지 3개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: 1 단계, 이미지 3개 중 2개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Ensure that the device is turned off before beginning.
      • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
      • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
      댓글 쓰기
    2. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: 2 단계, 이미지 3개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: 2 단계, 이미지 3개 중 2개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Using caution: 2 단계, 이미지 3개 중 3개
      • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
      • You want to make sure your separator goes through both sides of the bezel over top of the display.
      • The second photo is the layer you want your tool to pass through safely.
      • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
      댓글 쓰기
    3. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 3 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 3 단계, 이미지 2개 중 2개
      • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
      댓글 쓰기
    4. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 4 단계, 이미지 1개 중 1개
      • Gently lift the mid-frame out of the case with your hands.
      • Lift the side opposite of the power button out first.
      댓글 쓰기
    5. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 5 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
      댓글 쓰기
    6. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 6 단계, 이미지 1개 중 1개
      • Gently lift the battery from the frame.
      댓글 쓰기
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Motherboard: 7 단계, 이미지 1개 중 1개
      • Flip the black latch with a plastic opening tool, and then gently pull back the orange ribbon cable.
      댓글 쓰기
    2. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 8 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Flip the tiny off-white latch with angled precision tweezers toward the direction of the battery.
      • Gently peel back the orange ribbon cable.
      댓글 쓰기
    3. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 9 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Peel back the orange ribbon cable near the battery.
      • Flip the tiny black latch with angled precision tweezers toward the closest edge of the device.
      댓글 쓰기
    4. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 10 단계, 이미지 1개 중 1개
      • Peel back the white connector with your fingers.
      댓글 쓰기
    5. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 11 단계, 이미지 2개 중 1개 Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 11 단계, 이미지 2개 중 2개
      • Unscrew the six 3.0 mm Phillips #000 screws surrounding the motherboard.
      • Unscrew the one 2.5 mm Phillips #000 screw.
      • There is a little metal plate underneath the 2.5 mm screw and washers under four of the 3.0 mm screws.
      댓글 쓰기
    6. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement: 12 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to lift the motherboard upwards from the frame.
      댓글 쓰기
    1. Kindle Paperwhite 3rd Generation Screen/Display Touch Panel Replacement, Screen/Display Touch Panel: 13 단계, 이미지 1개 중 1개
      • The touchscreen is attached to the rest of the frame. Purchasing a new frame will require reattaching the motherboard and the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Micah Smart
회원 가입일: 02/10/16
3,428 평판
안내서 3개를 작성함
USF Tampa, Team 14-3, Lacy Spring 2016 USF Tampa, Team 14-3, Lacy Spring 2016 회원
USFT-LACY-S16S14G3
4 회원들
안내서 14개를 작성함
15가이드 댓글
hi there thank youfor your helping tutorial.
i just bought some used Kindle in order to buy at my shop. but i have a problem with some Kindle that i disassembled in order to have some spare parts and especially with the screen.
even after removing the screen it will stay frozen, even if i change the motherboard with a new one it will stay on the last screen shown.
Might you give me any explanation about the issue? and is that a way to reset the screen in order to use it as spare parts for other kindles?
charbel - 답글 공유
Thank you so much for this tutorial! Thanks to it I was able to replace a (physically) broken display. I un-assembled the entire device, let it rest until the shipment from China arrived and re-assembled it. It works flawlessly again and looks like new. One word of caution, though: The new display came without frame and removing the old display from the frame (both are pretty tightly glued together) resulted in quite some patient work and many pieces of broken glass (even with having it all heated). Anyway it worked out like a charm at the end!
Uwe Ritter - 답글 공유
Hello, where I can but a replacement screen for Kindle Paperwhite 300 ppi?? Thanks!!
Andres Barrera - 답글 공유
For anyone curious, the panel number for the PW3 is ED060KD1. You can use this to look it up on eBay etc.
Joshua Rong Xing Ong - 답글 공유
Do you have to take the broken screen out of the frame and then put the new one in? Is it difficult?
Chris - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 41
지난 30일: 232
전체 시간: 58,491
