주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kindle Voyage Ambient Light Sensor Replacement
필요한 것
  1. Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Kindle Voyage Ambient Light Sensor Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
    댓글 쓰기
  2. Kindle Voyage Ambient Light Sensor Replacement: 2 단계, 이미지 1개 중 1개
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
    댓글 쓰기
  3. Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 3개 중 1개 Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 3개 중 2개 Kindle Voyage Ambient Light Sensor Replacement: 3 단계, 이미지 3개 중 3개
    • Once the screws are removed, the back panel can slide off the device.
    댓글 쓰기
  4. Kindle Voyage Ambient Light Sensor Replacement: 4 단계, 이미지 2개 중 1개 Kindle Voyage Ambient Light Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the magnetic component with the magnetic head of the aluminum driver.
    댓글 쓰기
  5. Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 5 단계, 이미지 2개 중 1개 Kindle Voyage Ambient Light Sensor Replacement, Wifi Antenna: 5 단계, 이미지 2개 중 2개
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
    댓글 쓰기
  6. Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 3개 중 1개 Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 3개 중 2개 Kindle Voyage Ambient Light Sensor Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
    댓글 쓰기
  7. Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 7 단계, 이미지 2개 중 1개 Kindle Voyage Ambient Light Sensor Replacement, Ambient Light Sensor: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently remove the connector to the motherboard using tweezers.
    • Continue to carefully pull the rest of the connector from the adhesive connecting it to the Voyage.
    • Detach sensor from the top using fingers
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sean Yap
회원 가입일: 01/22/15
1,508 평판
안내서 6개를 작성함
Cal Poly, Team 19-12, Maness Winter 2015 Cal Poly, Team 19-12, Maness Winter 2015 회원
CPSU-MANESS-W15S19G12
5 회원들
안내서 13개를 작성함
1가이드 댓글
If i do this wiithout putting the lightsensor back on, can i then use the kindle without light ?
Best regards
Lasse
Beck - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 63
전체 시간: 3,141
