주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid KHM512ER Eject Button Spring Replacement
필요한 것
    1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: 1 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: 1 단계, 이미지 2개 중 2개
      • Insert the back of a plastic opening tool into one of the beater holes.
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      댓글 쓰기
    2. KitchenAid KHM512ER Eject Button Spring Replacement: 2 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Eject Button Spring Replacement: 2 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Eject Button Spring Replacement: 2 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to remove the speed knob.
      • Use a plastic opening tool to remove the long plastic piece
      • Use a plastic opening tool to remove the speed switch.
      댓글 쓰기
    3. KitchenAid KHM512ER Eject Button Spring Replacement: 3 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Eject Button Spring Replacement: 3 단계, 이미지 2개 중 2개
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      댓글 쓰기
    4. KitchenAid KHM512ER Eject Button Spring Replacement: 4 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Eject Button Spring Replacement: 4 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Eject Button Spring Replacement: 4 단계, 이미지 3개 중 3개
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly.
      • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
      댓글 쓰기
    5. KitchenAid KHM512ER Eject Button Spring Replacement: 5 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Eject Button Spring Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the eject button by pulling it from the inside of the mixer.
      • Hold the eject button firmly while pulling out the spring.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Yuriy Zaynulin
회원 가입일: 02/10/16
191 평판
안내서 1개를 작성함
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G3
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 37
전체 시간: 2,116
