주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid KHM512ER Power Cord Replacement
필요한 것
    1. KitchenAid KHM512ER Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Power Cord Replacement, Power Cord: 1 단계, 이미지 2개 중 2개
      • Insert the back of a plastic opening tool into one of the beater holes
      • Apply force to pull the circular plastic part off.
      • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
      댓글 쓰기
    2. KitchenAid KHM512ER Power Cord Replacement: 2 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Power Cord Replacement: 2 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Power Cord Replacement: 2 단계, 이미지 3개 중 3개
      • Use a plastic opening tool to remove the speed knob.
      • Pop up the panel with a plastic opening tool.
      • Use a plastic opening tool to pry the white plastic switch assembly out.
      댓글 쓰기
    3. KitchenAid KHM512ER Power Cord Replacement: 3 단계, 이미지 2개 중 1개 KitchenAid KHM512ER Power Cord Replacement: 3 단계, 이미지 2개 중 2개
      • Use a Phillips 2 screwdriver to remove the two 20.0mm screws that hold the bottom plastic piece.
      • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
      • Remove the bottom plastic piece using a plastic opening tool.
      댓글 쓰기
    4. KitchenAid KHM512ER Power Cord Replacement: 4 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Power Cord Replacement: 4 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Power Cord Replacement: 4 단계, 이미지 3개 중 3개
      • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
      • Use your hands to remove the motor assembly and circuit board.
      댓글 쓰기
    5. KitchenAid KHM512ER Power Cord Replacement: 5 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Power Cord Replacement: 5 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Power Cord Replacement: 5 단계, 이미지 3개 중 3개
      • Firmly grip the circuit board, and using pliers, remove the black and white power cord connectors from the circuit board.
      • Some force may be required. Be careful not to cut yourself on any electrical components.
      댓글 쓰기
    6. KitchenAid KHM512ER Power Cord Replacement: 6 단계, 이미지 3개 중 1개 KitchenAid KHM512ER Power Cord Replacement: 6 단계, 이미지 3개 중 2개 KitchenAid KHM512ER Power Cord Replacement: 6 단계, 이미지 3개 중 3개
      • Using a plastic opening tool, remove the white plastic clip on the inside of the bottom plastic piece.
      • Once it's loose, remove it with your fingers.
      • Pull the power cord through the hole.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brad Daniels
회원 가입일: 02/10/16
636 평판
안내서 3개를 작성함
USF Tampa, Team 2-3, Sullivan Spring 2016 USF Tampa, Team 2-3, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S2G3
3 회원들
안내서 16개를 작성함
1가이드 댓글
where to find this cord?
Markian G.G. - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 40
전체 시간: 4,511
