주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid KSB5CR Power Cable Replacement
필요한 것
    1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 1개 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 2개 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: 1 단계, 이미지 3개 중 3개
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
      댓글 쓰기
    2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: 2 단계, 이미지 1개 중 1개
      • Lift the back panel up, sliding it along the power cord.
      댓글 쓰기
    1. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: 3 단계, 이미지 1개 중 1개
      • Lift up on the power cable to pop it out of its holder.
      댓글 쓰기
    2. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: 4 단계, 이미지 2개 중 1개 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: 4 단계, 이미지 2개 중 2개
      • Be gentle with the knife or you will break the circuit board.
      • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
      • Repeat this process with the black copper wire.
      댓글 쓰기
    3. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: 5 단계, 이미지 2개 중 1개 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: 5 단계, 이미지 2개 중 2개
      • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Cameron Geehr
회원 가입일: 09/28/14
745 평판
안내서 6개를 작성함
Cal Poly, Team 12-5, Forte Fall 2014 Cal Poly, Team 12-5, Forte Fall 2014 회원
CPSU-FORTE-F14S12G5
5 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 16
전체 시간: 960
