주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid Professional 600 Bevel Gear Replacement
필요한 것
    1. KitchenAid Professional 600 Bevel Gear Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      댓글 쓰기
    2. KitchenAid Professional 600 Bevel Gear Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      댓글 쓰기
    3. KitchenAid Professional 600 Bevel Gear Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      댓글 쓰기
    1. KitchenAid Professional 600 Bevel Gear Replacement, Gear Housing Cover: 4 단계, 이미지 1개 중 1개
      • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
      • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
      댓글 쓰기
    2. KitchenAid Professional 600 Bevel Gear Replacement: 5 단계, 이미지 1개 중 1개
      • Take off the black housing cover.
      댓글 쓰기
    1. KitchenAid Professional 600 Bevel Gear Replacement, Bevel Gear: 6 단계, 이미지 3개 중 1개 KitchenAid Professional 600 Bevel Gear Replacement, Bevel Gear: 6 단계, 이미지 3개 중 2개 KitchenAid Professional 600 Bevel Gear Replacement, Bevel Gear: 6 단계, 이미지 3개 중 3개
      • To remove the Bevel Gear, remove the snap ring wrapped around the base of the gear using Snap Ring pliers.
      댓글 쓰기
    2. KitchenAid Professional 600 Bevel Gear Replacement: 7 단계, 이미지 1개 중 1개
      • Slide the Bevel Gear off.
      • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Luke
회원 가입일: 04/11/16
1,380 평판
안내서 5개를 작성함
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 42개를 작성함
14가이드 댓글
I was thinking , - my god what a excelent tec. contribution material before watched your naked hands whit a lot of greasy spots
Oscar Alfonso Lizaola Royval - 답글 공유
I’m from Ensenada Baja California “mother land of the internatiomal score baja off-road races“ and here we have a Doctor Simi drugstore’s where you can buy a pair of natural latex gloves whit or whitout powder s - m - l for less than one u.s. dollar. I buy gloves in monday’s because i pay 10 mexican pesos for it. “The little details son los que la cagan “
Need to know if after removing this bevel gear, does that allow the gear below it to be removed also? Because this is the one I need to replace.
Thanks
Richard Lee Watson - 답글 공유
Once the Bevel Gear is removed you will see a pin that can be pushed out with a punch or small screw driver. That allows to you to remove the Worm Follower Gear. Keep you hand under the machine as the whole shaft can slide down. It’s pretty straight forward.
Steve Nasralla - 답글 공유
I removed the snap ring but my bevel gear is locked and I cannot remove it. I suspect the pin located below it is broken. Any suggestion? What can I do to replace both bevel and worm gears?
scoretti@gmail.com - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 27
지난 30일: 145
전체 시간: 25,774
