주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid Professional 600 Speed Selector Replacement
필요한 것
    1. KitchenAid Professional 600 Speed Selector Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      댓글 쓰기
    2. KitchenAid Professional 600 Speed Selector Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      댓글 쓰기
    3. KitchenAid Professional 600 Speed Selector Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      댓글 쓰기
    1. KitchenAid Professional 600 Speed Selector Replacement, Speed Selector: 4 단계, 이미지 1개 중 1개
      • Locate the selector switch.
      • Remove the two Phillips #2 screws holding the selector switch in place.
      댓글 쓰기
    2. KitchenAid Professional 600 Speed Selector Replacement: 5 단계, 이미지 3개 중 1개 KitchenAid Professional 600 Speed Selector Replacement: 5 단계, 이미지 3개 중 2개 KitchenAid Professional 600 Speed Selector Replacement: 5 단계, 이미지 3개 중 3개
      • Unplug the cords attaching the drive motor to the switch.
      • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
      댓글 쓰기
    3. KitchenAid Professional 600 Speed Selector Replacement: 6 단계, 이미지 1개 중 1개
      • Pull out the Selector Switch.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tallon Dotinga
회원 가입일: 04/11/16
487 평판
안내서 2개를 작성함
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 27개를 작성함
8가이드 댓글
The instructions are to unplug the cords from the motor but the removed selector switch pictured shows the cords were removed from the selector switch. Is there a way to remove the cords from the selector switch without breaking them? donmilo@yahoo.com
Don Singleton - 답글 공유
The replacement part looks like a major part in the mixer and probably costs a bundle like most replacement parts… sometimes deems the replacement “not worthy” to repair!
It’s like a car that cost $25K but, all its parts if you buy them separately, it will cost you $150K !!!
david almogi - 답글 공유
The speed selector MSRP is $89.99 and can be found on places like eBay for $35-60. For only needing some simple tools and a little time, this fix saves you from the cost of buying a new one. These are designed to be repaired/refurbished.
Rachel Johnson - 답글 공유
When the speed selector is replaced, what is the rpm for “stir”?
everything is working, but it still seems too fast at 120rpm and I can’t see a difference between speeds 6, 8, & 10.
Jessica - 답글 공유
The advice about kitchenaid600 switch was good. The form to get me able to say thanks was not.
What thehelldoyouwant - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 127
전체 시간: 14,783
