주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
KitchenAid Professional 600 Worm Gear Replacement
필요한 것
    1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
      • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
      • Remove the silver band.
      댓글 쓰기
    2. KitchenAid Professional 600 Worm Gear Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four Phillips #2 screws located around the mixer where the band was removed.
      • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
      댓글 쓰기
    3. KitchenAid Professional 600 Worm Gear Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the top of the mixer to reveal the inner parts.
      • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
      댓글 쓰기
    1. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: 4 단계, 이미지 1개 중 1개
      • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
      • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
      댓글 쓰기
    2. KitchenAid Professional 600 Worm Gear Replacement: 5 단계, 이미지 1개 중 1개
      • Take off the black housing cover.
      댓글 쓰기
    1. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: 6 단계, 이미지 1개 중 1개
      • Remove the Worm Gear.
      • The Worm Gear is the part that is lying horizontal.
      • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Luke
회원 가입일: 04/11/16
1,380 평판
안내서 5개를 작성함
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016 회원
CPSU-MANESS-S16S25G4
4 회원들
안내서 27개를 작성함
1가이드 댓글
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 45
지난 30일: 173
전체 시간: 22,924
