주요 콘텐츠로 건너뛰기
Knot Thread to the Fabric (2 Ways)
필요한 것
  1. Knot Thread to the Fabric (2 Ways), Secure knot type 1: 1 단계, 이미지 3개 중 1개 Knot Thread to the Fabric (2 Ways), Secure knot type 1: 1 단계, 이미지 3개 중 2개 Knot Thread to the Fabric (2 Ways), Secure knot type 1: 1 단계, 이미지 3개 중 3개
    • On the backside of the fabric, make a very small stitch.
    • Pull the thread through, leaving a short tail of approximately 1/2 inch (~13 mm) to 1 inch (~25 mm).
    • Make another small stitch in the same area. Leave the needle piercing the fabric without pulling it all the way through.
  2. Knot Thread to the Fabric (2 Ways): 2 단계, 이미지 3개 중 1개 Knot Thread to the Fabric (2 Ways): 2 단계, 이미지 3개 중 2개 Knot Thread to the Fabric (2 Ways): 2 단계, 이미지 3개 중 3개
    • Take the thread that's emerging from the stitch and wrap it around the needle.
    • Wrap the thread around the needle a second time.
    • Push the wrapped threads down towards the base of the needle where it's emerging from the fabric.
  3. Knot Thread to the Fabric (2 Ways): 3 단계, 이미지 1개 중 1개
    • Pull the needle through the loops and pull the thread tight. The knot will lay flush with the fabric.
    • This video shows how to start a stitch with secure knot type 1.
    • This video shows how to end a stitch with secure knot type 1.
  4. Knot Thread to the Fabric (2 Ways), Secure knot type 2: 6 단계, 이미지 2개 중 1개 Knot Thread to the Fabric (2 Ways), Secure knot type 2: 6 단계, 이미지 2개 중 2개
  5. Knot Thread to the Fabric (2 Ways): 7 단계, 이미지 2개 중 1개 Knot Thread to the Fabric (2 Ways): 7 단계, 이미지 2개 중 2개
    • Make another small stitch in the same area, across the first stitch.
    • Pull the thread through but don't pull it tight, leaving a small loop.
  6. Knot Thread to the Fabric (2 Ways): 8 단계, 이미지 2개 중 1개 Knot Thread to the Fabric (2 Ways): 8 단계, 이미지 2개 중 2개
    • Thread the needle through the loop that was created in the previous step.
    • Gently pull the needle through the loop without pulling the thread tight, keeping the thread loop intact.
  7. Knot Thread to the Fabric (2 Ways): 9 단계, 이미지 2개 중 1개 Knot Thread to the Fabric (2 Ways): 9 단계, 이미지 2개 중 2개
    • Thread the needle through the loop again in the same direction as the previous step.
    • Pull the thread tight to secure the knot. The knot will lay flush against the fabric.
    • This video shows how to start a stitch with secure knot type 2.
    • This video shows how to end a stitch with secure knot type 2.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,544 평판
안내서 18개를 작성함
Patagonia Patagonia 회원
Community
17 회원들
안내서 168개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 23
지난 30일: 112
전체 시간: 513
