주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kobo Clara HD Repairs
필요한 것
    1. Kobo Clara HD Repairs, Before starting: 1 단계, 이미지 1개 중 1개
      • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
      댓글 쓰기
    2. Kobo Clara HD Repairs, Back cover: 2 단계, 이미지 3개 중 1개 Kobo Clara HD Repairs, Back cover: 2 단계, 이미지 3개 중 2개 Kobo Clara HD Repairs, Back cover: 2 단계, 이미지 3개 중 3개
      • Stick a plastic spudger into the gap between the front bezel and the back cover.
      • The back cover is held on by small plastic notches.
      • Slide the spudger along the seam to release the back cover.
      • Pry all the way around until the back cover pops free.
      댓글 쓰기
    3. Kobo Clara HD Repairs, Battery: 3 단계, 이미지 3개 중 1개 Kobo Clara HD Repairs, Battery: 3 단계, 이미지 3개 중 2개 Kobo Clara HD Repairs, Battery: 3 단계, 이미지 3개 중 3개
      • Gently pry up the white battery connector to pop it out of its bracket.
      댓글 쓰기
    4. Kobo Clara HD Repairs, Screen connectors: 4 단계, 이미지 3개 중 1개 Kobo Clara HD Repairs, Screen connectors: 4 단계, 이미지 3개 중 2개 Kobo Clara HD Repairs, Screen connectors: 4 단계, 이미지 3개 중 3개
      • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
      • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
      • Slide the ribbon cables out of the ZIF sockets.
      댓글 쓰기
    5. Kobo Clara HD Repairs, Battery: 5 단계, 이미지 2개 중 1개 Kobo Clara HD Repairs, Battery: 5 단계, 이미지 2개 중 2개
      • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
      댓글 쓰기
    6. Kobo Clara HD Repairs, Storage: 6 단계, 이미지 2개 중 1개 Kobo Clara HD Repairs, Storage: 6 단계, 이미지 2개 중 2개
      • All the storage is on a microSD card hidden inside the device.
      • Swap it out at your own risk.
      댓글 쓰기
    7. Kobo Clara HD Repairs, Logic board: 7 단계, 이미지 2개 중 1개 Kobo Clara HD Repairs, Logic board: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
      • Lift the logic board out from the top of the device.
      • There is a black sheet of plastic that sits under the logic board.
      댓글 쓰기
    8. Kobo Clara HD Repairs: 8 단계, 이미지 2개 중 1개 Kobo Clara HD Repairs: 8 단계, 이미지 2개 중 2개
      • To reassemble your device, follow these steps in reverse order.
      • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sparky
회원 가입일: 03/15/26
1,535 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 123
지난 30일: 450
전체 시간: 1,419
