주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kobo Mini Disassembly
필요한 것
    1. Kobo Mini Disassembly, Kobo Mini Disassembly: 1 단계, 이미지 2개 중 1개 Kobo Mini Disassembly, Kobo Mini Disassembly: 1 단계, 이미지 2개 중 2개
      • Pull on the corner to remove the cover.
      댓글 쓰기
    2. Kobo Mini Disassembly: 2 단계, 이미지 1개 중 1개
      • Remove the six screws.
      • Remove the back of the device.
      댓글 쓰기
    3. Kobo Mini Disassembly: 3 단계, 이미지 1개 중 1개
      • Remove the four screws from the mother board.
      • Remove the screen connector and the battery connector.
      • Remove the micro SD card.
      • Remove the motherboard from the chassis.
      댓글 쓰기
    4. Kobo Mini Disassembly: 4 단계, 이미지 2개 중 1개 Kobo Mini Disassembly: 4 단계, 이미지 2개 중 2개
      • Remove the four screws from the screen frame.
      • Remove the screen
      댓글 쓰기
    5. Kobo Mini Disassembly: 5 단계, 이미지 1개 중 1개
      • And we finally finished.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Gabriel Bédard
회원 가입일: 06/07/18
360 평판
안내서 1개를 작성함
9가이드 댓글
Just a quick note, I noticed that the SD card in the teardown is a 4gb one. The Kobo Mini has only 2gb of storage. There's just under 2gb of unpartitioned space. You can use a partition manager to extend out the last partition to fill the card, and get close to 4gb of space.
There's a guide over on Mobile Read: https://www.mobileread.com/forums/showth...
Stephanie Raccoon - 답글 공유
Yes I think
Gabriel Bédard - 답글 공유
Thanks for the teardown! See https://www.mobileread.com/forums/showth... and https://wiki.mobileread.com/wiki/Kobo_Mi... for more disassembly advice and information about the components used.
I would be concerned about the reliability of the 4GB micro SD cards when extended to use the full unpartitioned space. While I could imagine a situation where 4GB cards were used due to unavailability of 2GB cards, there doesn’t seem to be a good reason to only format them to 2GB unless they were only guaranteed to reliably hold 2GB of data. In other words, I wonder if they were originally 4GB cards that failed some QA test and were only rated for use as 2GB capacity cards.
David Boddie - 답글 공유
How do you remove the battery connector? Simply pull? Remove the black little things on the sides in some way?
jasonhayden - 답글 공유
Yes you just need to pull it from the motherboard
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 125
전체 시간: 7,695
