주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kodak EasyShare C713 Lens Replacement
필요한 것
  1. Kodak EasyShare C713 Lens Replacement, Batteries: 1 단계, 이미지 1개 중 1개
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
    댓글 쓰기
  2. Kodak EasyShare C713 Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the old batteries.
    댓글 쓰기
  3. Kodak EasyShare C713 Lens Replacement, Outer Case: 3 단계, 이미지 3개 중 1개 Kodak EasyShare C713 Lens Replacement, Outer Case: 3 단계, 이미지 3개 중 2개 Kodak EasyShare C713 Lens Replacement, Outer Case: 3 단계, 이미지 3개 중 3개
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
    댓글 쓰기
  4. Kodak EasyShare C713 Lens Replacement: 4 단계, 이미지 3개 중 1개 Kodak EasyShare C713 Lens Replacement: 4 단계, 이미지 3개 중 2개 Kodak EasyShare C713 Lens Replacement: 4 단계, 이미지 3개 중 3개
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
    댓글 쓰기
  5. Kodak EasyShare C713 Lens Replacement, LCD: 5 단계, 이미지 1개 중 1개
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
    댓글 쓰기
  6. Kodak EasyShare C713 Lens Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
    댓글 쓰기
  7. Kodak EasyShare C713 Lens Replacement: 7 단계, 이미지 2개 중 1개 Kodak EasyShare C713 Lens Replacement: 7 단계, 이미지 2개 중 2개
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
    댓글 쓰기
  8. Kodak EasyShare C713 Lens Replacement: 8 단계, 이미지 1개 중 1개
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
    댓글 쓰기
  9. Kodak EasyShare C713 Lens Replacement: 9 단계, 이미지 1개 중 1개
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
    댓글 쓰기
  10. Kodak EasyShare C713 Lens Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the LCD ribbon cable from inside the black tab.
    댓글 쓰기
  11. Kodak EasyShare C713 Lens Replacement, Lens: 11 단계, 이미지 1개 중 1개
    • Using a fingertip, flip the black tab near the top of the camera.
    • Remove the ribbon connector from inside the black tab.
    댓글 쓰기
  12. Kodak EasyShare C713 Lens Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
    댓글 쓰기
  13. Kodak EasyShare C713 Lens Replacement: 13 단계, 이미지 1개 중 1개
    • Desolder the upper points.
    • There is a series of solder points in a rectangular area in the upper middle of the camera.
    • There is a large solder point in the upper right.
    댓글 쓰기
  14. Kodak EasyShare C713 Lens Replacement: 14 단계, 이미지 1개 중 1개
    • Turn the camera over.
    • Remove the silver 2.2mm battery cap screw.
    댓글 쓰기
  15. Kodak EasyShare C713 Lens Replacement: 15 단계, 이미지 2개 중 1개 Kodak EasyShare C713 Lens Replacement: 15 단계, 이미지 2개 중 2개
    • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
    댓글 쓰기
  16. Kodak EasyShare C713 Lens Replacement: 16 단계, 이미지 3개 중 1개 Kodak EasyShare C713 Lens Replacement: 16 단계, 이미지 3개 중 2개 Kodak EasyShare C713 Lens Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the lens assembly with your fingers.
    • You may need to wiggle it back and forth until it comes loose.
    • Do not touch the marked areas. This will cause the camera to take blurry pictures.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Taggart Ashby
회원 가입일: 04/15/10
360 평판
안내서 4개를 작성함
Cal Poly, Team 26-19, Regan Spring 2010 Cal Poly, Team 26-19, Regan Spring 2010 회원
CPSU-REGAN-S10S26G19
4 회원들
안내서 14개를 작성함
1가이드 댓글
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 39
전체 시간: 7,836
