주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kodak EasyShare M381 Screen Replacement
필요한 것
    1. Kodak EasyShare M381 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • First, press in and slide forward the battery latch as indicated by the arrow.
      댓글 쓰기
    2. Kodak EasyShare M381 Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Press down on battery until you hear a click and release it. Battery should easily slide out.
      댓글 쓰기
    1. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 3 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 3 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: 3 단계, 이미지 3개 중 3개
      • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
      • Using a magnetized surface to keep from losing screws may be very helpful.
      댓글 쓰기
    2. Kodak EasyShare M381 Screen Replacement: 4 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Screen Replacement: 4 단계, 이미지 2개 중 2개
      • Using both hands, carefully pull the frame apart from the camera.
      댓글 쓰기
    1. Kodak EasyShare M381 Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
      • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
      댓글 쓰기
    2. Kodak EasyShare M381 Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Remove dial button located on top of camera, by gently pulling up.
      댓글 쓰기
    3. Kodak EasyShare M381 Screen Replacement: 7 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Screen Replacement: 7 단계, 이미지 2개 중 2개
      • Starting at one side, carefully work the chrome frame off of the camera itself.
      • Be careful not to disturb the shutter or flash buttons on top of the camera.
      댓글 쓰기
    4. Kodak EasyShare M381 Screen Replacement: 8 단계, 이미지 1개 중 1개
      • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
      댓글 쓰기
    5. Kodak EasyShare M381 Screen Replacement: 9 단계, 이미지 3개 중 1개 Kodak EasyShare M381 Screen Replacement: 9 단계, 이미지 3개 중 2개 Kodak EasyShare M381 Screen Replacement: 9 단계, 이미지 3개 중 3개
      • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
      • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
      • Slide panel away from camera.
      댓글 쓰기
    6. Kodak EasyShare M381 Screen Replacement: 10 단계, 이미지 2개 중 1개 Kodak EasyShare M381 Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
      • Screen should now be detached. Gently lift it away from the base of the camera.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Christina Hamby
회원 가입일: 01/30/15
449 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 11
지난 30일: 34
전체 시간: 918
