주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Konica Minolta DiMAGE Z3 Battery Replacement
    1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 1개 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 2개
      • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
      • Lift the door up to open.
      댓글 쓰기
    2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: 2 단계, 이미지 1개 중 1개
      • Insert the four batteries inside of the battery chamber door.
      • Make sure the positive and negative battery terminals are in the correct position.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Hieu Ngo
회원 가입일: 03/22/17
431 평판
안내서 4개를 작성함
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G4
4 회원들
안내서 28개를 작성함
1가이드 댓글
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 40
전체 시간: 1,829
