주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Konica Minolta DiMAGE Z3 LCD Screen Replacement
필요한 것
    1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 1개 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: 1 단계, 이미지 2개 중 2개
      • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
      • Lift the door up to open.
      댓글 쓰기
    2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: 2 단계, 이미지 1개 중 1개
      • Insert the four batteries inside of the battery chamber door.
      • Make sure the positive and negative battery terminals are in the correct position.
      댓글 쓰기
    1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 3 단계, 이미지 2개 중 1개 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: 3 단계, 이미지 2개 중 2개
      • Use a screwdriver to remove the four viewfinder cover screws.
      댓글 쓰기
    2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: 4 단계, 이미지 1개 중 1개
      • Remove the 2 small screws under the viewfinder.
      댓글 쓰기
    3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: 5 단계, 이미지 1개 중 1개
      • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
      • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
      댓글 쓰기
    4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: 6 단계, 이미지 1개 중 1개
      • Remove 6 screws on the bottom panel.
      댓글 쓰기
    5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: 7 단계, 이미지 1개 중 1개
      • Remove 1 screw on the outer side of the battery chamber.
      • This will be under the rubber grip.
      댓글 쓰기
    6. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Remove 1 screw inside the battery chamber.
      댓글 쓰기
    7. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Pull the wrist strap away from the front of the camera to remove it.
      • Then carefully pull the back casing apart from the camera.
      댓글 쓰기
    8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the 3 screws that attach the LCD screen to the circuit board.
      댓글 쓰기
    9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Gently remove the LCD screen from the circuit board.
      • There will be a ribbon cable and some wires attached to the LCD screen.
      댓글 쓰기
    10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
      • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Hieu Ngo
회원 가입일: 03/22/17
431 평판
안내서 4개를 작성함
UMass Dartmouth, Team S7-G4, Julie Spring 2017 UMass Dartmouth, Team S7-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S7G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 33
전체 시간: 1,230
