주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Koosh Vortex Tornado Loading Spring Replacement
필요한 것
    1. Koosh Vortex Tornado Loading Spring Replacement, Barrel Shield Spring: 1 단계, 이미지 1개 중 1개
      • Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
      댓글 쓰기
    2. Koosh Vortex Tornado Loading Spring Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
      댓글 쓰기
    3. Koosh Vortex Tornado Loading Spring Replacement: 3 단계, 이미지 1개 중 1개
      • Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
      댓글 쓰기
    1. Koosh Vortex Tornado Loading Spring Replacement, Trigger: 4 단계, 이미지 1개 중 1개
      • Slide the barrel shield and shield slide off of the gun and set aside.
      댓글 쓰기
    2. Koosh Vortex Tornado Loading Spring Replacement: 5 단계, 이미지 1개 중 1개
      • Slide the rubber ring off of the barrel and set it aside.
      댓글 쓰기
    3. Koosh Vortex Tornado Loading Spring Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the yellow trigger from its pin and set aside.
      댓글 쓰기
    1. Koosh Vortex Tornado Loading Spring Replacement, Loading Spring: 7 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to unscrew the two 12 mm long washer head screws from the yellow loading bar lever.
      댓글 쓰기
    2. Koosh Vortex Tornado Loading Spring Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the yellow lever bar out of place and set aside.
      댓글 쓰기
    3. Koosh Vortex Tornado Loading Spring Replacement: 9 단계, 이미지 1개 중 1개
      • Use a Phillips #1 Screwdriver to unscrew the six 10 mm long screws from the central firing assembly.
      • Use Phillips #1 Screwdriver to unscrew the four 9 mm long screws from the central firing assembly.
      댓글 쓰기
    4. Koosh Vortex Tornado Loading Spring Replacement: 10 단계, 이미지 1개 중 1개
      • Pull the shell of the central firing assembly aside off (contains the loading spring).
      댓글 쓰기
    5. Koosh Vortex Tornado Loading Spring Replacement: 11 단계, 이미지 2개 중 1개 Koosh Vortex Tornado Loading Spring Replacement: 11 단계, 이미지 2개 중 2개
      • Open the back side of the central firing assembly apart to expose the loading spring. Remove it, and change it with your desired spring.
      • The two sides cannot be fully separated due to a pin holding the yellow collar tightly together.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Lingbin Meng
회원 가입일: 02/16/16
204 평판
안내서 2개를 작성함
IUPUI, Team 2-4, Harley Spring 2016 IUPUI, Team 2-4, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G4
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 44
전체 시간: 1,155
