주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Krups CafeExpress FMA110 Disassembly
필요한 것
  1. Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: 1 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly, Krups CafeExpress FMA110 Disassembly: 1 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the four 13.8 mm screws on the bottom of the device.
    • Remove the metal plate.
    댓글 쓰기
  2. Krups CafeExpress FMA110 Disassembly: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the two 16.7 mm screws to release the power cable.
    댓글 쓰기
  3. Krups CafeExpress FMA110 Disassembly: 3 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 3 단계, 이미지 2개 중 2개
    • Pinch the clamps around the thinner part of the silicon tubing and slide them towards the corner of the tube.
    댓글 쓰기
  4. Krups CafeExpress FMA110 Disassembly: 4 단계, 이미지 1개 중 1개
    • Carefully pull the silicon tubing off of the metal tube.
    댓글 쓰기
  5. Krups CafeExpress FMA110 Disassembly: 5 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 5 단계, 이미지 2개 중 2개
    • Pinch the clamps around the thicker part of the silicon tubing and slide them towards the corner of the tube.
    댓글 쓰기
  6. Krups CafeExpress FMA110 Disassembly: 6 단계, 이미지 1개 중 1개
    • Carefully remove the silicon tubing from the upper reservoir.
    댓글 쓰기
  7. Krups CafeExpress FMA110 Disassembly: 7 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the three 13.8 mm screws towards the back of the base.
    댓글 쓰기
  8. Krups CafeExpress FMA110 Disassembly: 8 단계, 이미지 1개 중 1개
    • Separate the base of the device from the upper reservoir.
    댓글 쓰기
  9. Krups CafeExpress FMA110 Disassembly: 9 단계, 이미지 1개 중 1개
    • Push the switch out from the inside, releasing it from the plastic base.
    댓글 쓰기
  10. Krups CafeExpress FMA110 Disassembly: 10 단계, 이미지 1개 중 1개
    • Loosen the white ring from the switch and squeeze it to slide it through the opening in the base.
    댓글 쓰기
  11. Krups CafeExpress FMA110 Disassembly: 11 단계, 이미지 1개 중 1개
    • Slide the rest of the switch back through the hole in the base.
    댓글 쓰기
  12. Krups CafeExpress FMA110 Disassembly: 12 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 12 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the three 15.8 mm screws to release the inner components from the plastic base.
    댓글 쓰기
  13. Krups CafeExpress FMA110 Disassembly: 13 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 13 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the two 11.5 mm screws on either side of the horizontal metal bracket.
    댓글 쓰기
  14. Krups CafeExpress FMA110 Disassembly: 14 단계, 이미지 1개 중 1개
    • Remove the horizontal bracket to separate the heating element and wires from the hot plate.
    댓글 쓰기
  15. Krups CafeExpress FMA110 Disassembly: 15 단계, 이미지 1개 중 1개
    • Disconnect the wire connectors from the thermal switch.
    댓글 쓰기
  16. Krups CafeExpress FMA110 Disassembly: 16 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the two 7.6 mm screws and remove the thermal switch.
    댓글 쓰기
  17. Krups CafeExpress FMA110 Disassembly: 17 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 17 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the two 9.9 mm screws from the hot plate.
    • Separate the hot plate from its frame.
    댓글 쓰기
  18. Krups CafeExpress FMA110 Disassembly: 18 단계, 이미지 2개 중 1개 Krups CafeExpress FMA110 Disassembly: 18 단계, 이미지 2개 중 2개
    • Once the heating element reaches a certain temperature, the thermal switch shuts it off to prevent it from overheating.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sam Sugerman
회원 가입일: 09/16/21
327 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 50
전체 시간: 827
