주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kurio Xtreme Power/Volume Buttons Replacement
필요한 것
    1. Kurio Xtreme Power/Volume Buttons Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      댓글 쓰기
    2. Kurio Xtreme Power/Volume Buttons Replacement: 2 단계, 이미지 2개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      댓글 쓰기
    3. Kurio Xtreme Power/Volume Buttons Replacement: 3 단계, 이미지 3개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 3 단계, 이미지 3개 중 2개 Kurio Xtreme Power/Volume Buttons Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      댓글 쓰기
    1. Kurio Xtreme Power/Volume Buttons Replacement, Power/Volume Buttons: 4 단계, 이미지 1개 중 1개
      • Remove the three 4 mm screws on the motherboard with a Phillips #000 screwdriver.
      댓글 쓰기
    2. Kurio Xtreme Power/Volume Buttons Replacement: 5 단계, 이미지 2개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
      댓글 쓰기
    3. Kurio Xtreme Power/Volume Buttons Replacement: 6 단계, 이미지 2개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
      댓글 쓰기
    4. Kurio Xtreme Power/Volume Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the speakers out of the plastic molds by lifting up the black and red wires.
      • Be careful not to disconnect the black and red wires from the motherboard.
      댓글 쓰기
    5. Kurio Xtreme Power/Volume Buttons Replacement: 8 단계, 이미지 2개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the motherboard by lifting it out of the casing. Set it upside down below the casing.
      • The motherboard will still be connected to the battery and the speakers.
      댓글 쓰기
    6. Kurio Xtreme Power/Volume Buttons Replacement: 9 단계, 이미지 3개 중 1개 Kurio Xtreme Power/Volume Buttons Replacement: 9 단계, 이미지 3개 중 2개 Kurio Xtreme Power/Volume Buttons Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the volume buttons and/or power button by soldering them at their bases.
      • Volume down
      • Volume up
      • Power
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mallory Myers
회원 가입일: 09/22/15
1,190 평판
안내서 7개를 작성함
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G10
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 1,138
