주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kurio Xtreme Touch Screen Replacement
필요한 것
    1. Kurio Xtreme Touch Screen Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
      댓글 쓰기
    2. Kurio Xtreme Touch Screen Replacement: 2 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
      • There are two screws on each side of the device (four total).
      댓글 쓰기
    3. Kurio Xtreme Touch Screen Replacement: 3 단계, 이미지 3개 중 1개 Kurio Xtreme Touch Screen Replacement: 3 단계, 이미지 3개 중 2개 Kurio Xtreme Touch Screen Replacement: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
      • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
      • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
      • Carefully lift the back panel off of the rest of the device.
      댓글 쓰기
    1. Kurio Xtreme Touch Screen Replacement, Touch Screen: 4 단계, 이미지 1개 중 1개
      • Unscrew the three 4 mm screws with a Phillips #000 screwdriver.
      댓글 쓰기
    2. Kurio Xtreme Touch Screen Replacement: 5 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
      댓글 쓰기
    3. Kurio Xtreme Touch Screen Replacement: 6 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
      댓글 쓰기
    4. Kurio Xtreme Touch Screen Replacement: 7 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
      • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
      • Carefully lift the battery out of the device and set it aside.
      • Be careful not to disconnect the black and red wires from the motherboard when setting the battery aside.
      댓글 쓰기
    5. Kurio Xtreme Touch Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires. Set the speakers aside.
      • Be careful not to disconnect the black and red wires from the motherboard when setting the speakers aside.
      댓글 쓰기
    6. Kurio Xtreme Touch Screen Replacement: 9 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the motherboard by lifting it out of the casing and set it aside along with the battery and speakers.
      • The motherboard will still be connected to the battery, speakers, and the gray ground wire.
      댓글 쓰기
    7. Kurio Xtreme Touch Screen Replacement: 10 단계, 이미지 1개 중 1개
      • Carefully peel the ground wire tape off of the blue front screen panel.
      • It is not necessary to peel the tape off of the back of the silver LCD screen.
      댓글 쓰기
    8. Kurio Xtreme Touch Screen Replacement: 11 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 11 단계, 이미지 2개 중 2개
      • Pry open all 7 of the blue clamps by wedging the plastic opening tool under them and bending them backward.
      • The clamps will not "snap" open. This step requires you to actually bend the plastic back.
      댓글 쓰기
    9. Kurio Xtreme Touch Screen Replacement: 12 단계, 이미지 2개 중 1개 Kurio Xtreme Touch Screen Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the LCD display from the blue touch screen casing by gently shaking them apart in the palm of your hand.
      • This could be stuck on, so you need heat to loosen the glue.
      • Be careful when prying the digitzer from the plastic, if you bend it too much it can break the frame!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Mallory Myers
회원 가입일: 09/22/15
1,190 평판
안내서 7개를 작성함
Baylor, Team 6-10, Williams Fall 2015 Baylor, Team 6-10, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G10
3 회원들
안내서 14개를 작성함
2가이드 댓글
Thanks - very good guide! For the investment of an iFixit toolset and less than 10 GBP for a replacement digitizer, I was able to restore my little boy's treasure!
Patrick Niessen - 답글 공유
Thank you so much for the Guide!! Helped save Christmas!!! The steps were easy to follow and my kids tablets are back to new.
tdd82 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 39
전체 시간: 3,999
