주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG 305C Touch Screen Assembly Replacement
필요한 것
    1. LG 305C  Touch Screen Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
      댓글 쓰기
    2. LG 305C  Touch Screen Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
      댓글 쓰기
    1. LG 305C  Touch Screen Assembly Replacement, Touch Screen: 3 단계, 이미지 2개 중 1개 LG 305C  Touch Screen Assembly Replacement, Touch Screen: 3 단계, 이미지 2개 중 2개
      • Unscrew the back of your device and on the white strip underneath, it should read LG 305C.
      • Note: If it does not read LG305C as the model number, please refer to another guide in order to replace your screen.
      댓글 쓰기
    2. LG 305C  Touch Screen Assembly Replacement, SD Card Removal: 4 단계, 이미지 1개 중 1개
      댓글 쓰기
    3. LG 305C  Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 1개 LG 305C  Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 2개 LG 305C  Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Use a Phillips #00 screwdriver to remove the seven screws that are located along the edges of the device.
      댓글 쓰기
    4. LG 305C  Touch Screen Assembly Replacement: 6 단계, 이미지 2개 중 1개 LG 305C  Touch Screen Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Using your plastic pry tool, pry along the edges of plastic side of the screen to loosen and separate the first screen layer.
      • As shown in Picture 2, push in the notch along the edge of the charging port.
      댓글 쓰기
    5. LG 305C  Touch Screen Assembly Replacement: 7 단계, 이미지 3개 중 1개 LG 305C  Touch Screen Assembly Replacement: 7 단계, 이미지 3개 중 2개 LG 305C  Touch Screen Assembly Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the front end of the screen by gently swinging it out from its notched in position as shown.
      댓글 쓰기
    6. LG 305C  Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 1개 LG 305C  Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 2개
      • Gently pry off the touch screen connection attached to the motherboard with your finger.
      • Once detached, gently separate the motherboard and plastic screen mold. It should look the same as Picture 2
      댓글 쓰기
결론
To reassemble your device, follow the steps in reverse. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
alex Benitez
회원 가입일: 10/24/16
124 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 21
전체 시간: 659
