주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Ally VS740 Camera Flash Replacement
필요한 것
  1. LG Ally VS740 Camera Flash Replacement, Camera Flash: 1 단계, 이미지 1개 중 1개
    • Hold phone in hand, then flip to battery pack
    • Take off battery cover
    댓글 쓰기
  2. LG Ally VS740 Camera Flash Replacement: 2 단계, 이미지 1개 중 1개
    • Remove battery
    • Locate the six surrounding screws located on the edge of the inner compartment, including the two screws on the metal piece where the battery was once placed.
    댓글 쓰기
  3. LG Ally VS740 Camera Flash Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the phone open. Notice on the edges around the keyboard, there is a thick casing. Remove this casing, instructions below…
    • Placing two dominant fingers on the back plate where the battery was, use your thumb finger nail (or prying utensil) and place it on the edge of this thin casing. Firmly, push down with your finger nail (prying utensil) around the casing from left to right. Disconnect casing from keyboard section. Flip the phone over and remove it.
    댓글 쓰기
  4. LG Ally VS740 Camera Flash Replacement: 4 단계, 이미지 2개 중 1개 LG Ally VS740 Camera Flash Replacement: 4 단계, 이미지 2개 중 2개
    • Using your prying tool, lift the green circuit board platform off the black casing and gently disconnect the connection point between the tether and the green circuit board.
    • Flip phone over, and notice where the camera lies on the other side, there are three small clips connecting a black casing over the section of the phone. Gently using your hands or the prying tool, take these clips off.
    댓글 쓰기
  5. LG Ally VS740 Camera Flash Replacement: 5 단계, 이미지 1개 중 1개
    • The white rectangle with the yellow square is the flash. Gently lift up and disconnect flash module. Take your new flash and aligning the connection point to the connection hole, push it down firmly until it is snug in place. Follow the steps backwards to put phone back together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Billy Carias
회원 가입일: 10/23/14
219 평판
안내서 2개를 작성함
UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S5G6
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 24
전체 시간: 715
