주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG BP220 Motherboard Replacement
필요한 것
    1. LG BP220 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 LG BP220 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      댓글 쓰기
    2. LG BP220 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 LG BP220 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 LG BP220 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      댓글 쓰기
    3. LG BP220 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      댓글 쓰기
    4. LG BP220 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 LG BP220 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
      댓글 쓰기
    5. LG BP220 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 LG BP220 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 LG BP220 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
      • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
      • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
      • Remove the power cord from the panel by carefully sliding it upwards from its seating.
      댓글 쓰기
    6. LG BP220 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 LG BP220 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
      • One screw inbetween the audio/video jacks
      • One screw to the bottom right of the audio/video jacks
      • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
      댓글 쓰기
    7. LG BP220 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 LG BP220 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
      • Handle the motherboards with care. They are fragile.
      • Beware of the capacitors as they may shock you when touched.
      • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
      • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
      • Use both hands to carefully lift the motherboard unit away from the player.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bart Quicho
회원 가입일: 01/13/15
520 평판
안내서 3개를 작성함
UW Tacoma, Team 1-1, Rose Winter 2015 UW Tacoma, Team 1-1, Rose Winter 2015 회원
UWT-ROSE-W15S1G1
4 회원들
안내서 15개를 작성함
1가이드 댓글
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 50
전체 시간: 5,364
