주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG CU515 Motherboard Replacement
필요한 것
  1. LG CU515 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG CU515 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use your thumb to press down and slide off the back cover of the phone.
    댓글 쓰기
  2. LG CU515 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 LG CU515 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 LG CU515 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Take out the battery by levering it out towards the bottom of the phone.
    댓글 쓰기
  3. LG CU515 Motherboard Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
    댓글 쓰기
  4. LG CU515 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
    댓글 쓰기
  5. LG CU515 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 LG CU515 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 LG CU515 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
    댓글 쓰기
  6. LG CU515 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
    댓글 쓰기
  7. LG CU515 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
    댓글 쓰기
  8. LG CU515 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Zack Mintzer
회원 가입일: 04/16/13
1 평판
안내서 6개를 작성함
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G55
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 593
