주요 콘텐츠로 건너뛰기
LG Chocolate 3 Display Connector Replacement
필요한 것
  1. LG Chocolate 3 Display Connector Replacement, Display Connector: 1 단계, 이미지 1/1
    • Remove the battery and expose the motherboard following the General Disassembly LG VX8560. You will have to replace the side keys once finished with this guide.
    • Locate intertwined blue and red wire (screen display connector.)
  2. LG Chocolate 3 Display Connector Replacement: 2 단계, 이미지 1/1
    • (Ignore this step if the screen display connector is already separated from the motherboard) Using the spudger, place the pointy end between the plastic end of the wire and the motherboard and lift/push wire from the motherboard socket. You should see two golden pins protruding from the plastic.
    • Align the two golden pins at the end of the wire with its respective socket on the motherboard and gently push down until you hear a click-sound.
    • To reassemble your device, follow Side Keys Installation in reverse order.
결승점
Mitchel
회원 가입일: 04/18/13
1 평판
안내서 1개 작성함
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G62
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 334
