주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Chocolate 3 Keypad Replacement
필요한 것
  1. LG Chocolate 3 Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
    댓글 쓰기
  2. LG Chocolate 3 Keypad Replacement: 2 단계, 이미지 3개 중 1개 LG Chocolate 3 Keypad Replacement: 2 단계, 이미지 3개 중 2개 LG Chocolate 3 Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Using your index finger lift and remove the battery from the phone.
    댓글 쓰기
  3. LG Chocolate 3 Keypad Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    댓글 쓰기
  4. LG Chocolate 3 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    댓글 쓰기
  5. LG Chocolate 3 Keypad Replacement: 5 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    댓글 쓰기
  6. LG Chocolate 3 Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    댓글 쓰기
  7. LG Chocolate 3 Keypad Replacement: 7 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully remove the rear case from the phone.
    댓글 쓰기
  8. LG Chocolate 3 Keypad Replacement, Side Buttons: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the music button found on the side of the phone.
    댓글 쓰기
  9. LG Chocolate 3 Keypad Replacement: 9 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 9 단계, 이미지 2개 중 2개
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
    댓글 쓰기
  10. LG Chocolate 3 Keypad Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
    • Use the flat end of the spudger to lift the orange display data cable.
    댓글 쓰기
  11. LG Chocolate 3 Keypad Replacement: 11 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 11 단계, 이미지 2개 중 2개
    • Carefully insert the plastic opening tool between the motherboard and the back of the phone.
    댓글 쓰기
  12. LG Chocolate 3 Keypad Replacement: 12 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 12 단계, 이미지 2개 중 2개
    • Use your thumb and index finger to carefully lift and separate the motherboard from the back of the phone.
    • Be cautious of the orange display data cable, it may stick to the motherboard.
    • To avoid this, lift the data cable away from the motherboard before removal.
    댓글 쓰기
  13. LG Chocolate 3 Keypad Replacement, Keypad: 13 단계, 이미지 1개 중 1개
    • Open the phone.
    • Keep the phone open by keeping a firm grip on the hinges to avoid any damages to the phone.
    댓글 쓰기
  14. LG Chocolate 3 Keypad Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the orange data cable up so that it is elevated.
    • Gently use a finger to lift the keypad out.
    댓글 쓰기
  15. LG Chocolate 3 Keypad Replacement: 15 단계, 이미지 1개 중 1개
    • Insert the spudger in between the keypad and the phone.
    • Lift the keypad to seperate it from the phone.
    댓글 쓰기
  16. LG Chocolate 3 Keypad Replacement: 16 단계, 이미지 2개 중 1개 LG Chocolate 3 Keypad Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the damaged keypad.
    • Insert the replacement keypad.
    • Reassemble the phone after the broken keypad is replaced.
    댓글 쓰기
결론
To reassemble this device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
17다른 기여자 명과 함께
Brenna Yagade
회원 가입일: 04/15/13
40 평판
안내서 6개를 작성함
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G35
5 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 804
