주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Chocolate Keypad Replacement
필요한 것
  1. LG Chocolate Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    댓글 쓰기
  2. LG Chocolate Keypad Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    댓글 쓰기
  3. LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 1개 LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 2개 LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 3개
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    댓글 쓰기
  4. LG Chocolate Keypad Replacement, Sliding Front: 4 단계, 이미지 1개 중 1개
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    댓글 쓰기
  5. LG Chocolate Keypad Replacement: 5 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 5 단계, 이미지 2개 중 2개
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    댓글 쓰기
  6. LG Chocolate Keypad Replacement: 6 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 6 단계, 이미지 2개 중 2개
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    댓글 쓰기
  7. LG Chocolate Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Pry off the back cover from the front of the case using a plastic opening tool.
    댓글 쓰기
  8. LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 1개 LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 2개 LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 3개
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
    댓글 쓰기
  9. LG Chocolate Keypad Replacement: 9 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 9 단계, 이미지 2개 중 2개
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
    댓글 쓰기
  10. LG Chocolate Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Unhook the ribbon cable using that flat side of a spudger.
    댓글 쓰기
  11. LG Chocolate Keypad Replacement: 11 단계, 이미지 1개 중 1개
    • Next, carefully remove the tape from the LCD board.
    댓글 쓰기
  12. LG Chocolate Keypad Replacement: 12 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 12 단계, 이미지 2개 중 2개
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
    댓글 쓰기
  13. LG Chocolate Keypad Replacement, LCD Screen: 13 단계, 이미지 1개 중 1개
    • The LCD screen is no longer connected to the LCD board.
    댓글 쓰기
  14. LG Chocolate Keypad Replacement, Keypad: 14 단계, 이미지 1개 중 1개
    • Push the keypad out from the front of the phone and remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Maci Miri
회원 가입일: 01/18/13
39 평판
안내서 3개를 작성함
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 회원
CPSU-REGAN-W13S19G46
4 회원들
안내서 44개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 35
전체 시간: 676
