주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Chocolate Sliding Mechanism Replacement
필요한 것
  1. LG Chocolate Sliding Mechanism Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Chocolate Sliding Mechanism Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    댓글 쓰기
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    댓글 쓰기
  3. LG Chocolate Sliding Mechanism Replacement: 3 단계, 이미지 3개 중 1개 LG Chocolate Sliding Mechanism Replacement: 3 단계, 이미지 3개 중 2개 LG Chocolate Sliding Mechanism Replacement: 3 단계, 이미지 3개 중 3개
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    댓글 쓰기
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: 4 단계, 이미지 1개 중 1개
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    댓글 쓰기
  5. LG Chocolate Sliding Mechanism Replacement: 5 단계, 이미지 2개 중 1개 LG Chocolate Sliding Mechanism Replacement: 5 단계, 이미지 2개 중 2개
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    댓글 쓰기
  6. LG Chocolate Sliding Mechanism Replacement: 6 단계, 이미지 2개 중 1개 LG Chocolate Sliding Mechanism Replacement: 6 단계, 이미지 2개 중 2개
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    댓글 쓰기
  7. LG Chocolate Sliding Mechanism Replacement: 7 단계, 이미지 1개 중 1개
    • Pry off the back cover from the front of the case using a plastic opening tool.
    댓글 쓰기
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
    댓글 쓰기
  9. LG Chocolate Sliding Mechanism Replacement: 9 단계, 이미지 1개 중 1개
    • Remove sliding mechanism.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Thomas
회원 가입일: 01/18/13
91 평판
안내서 4개를 작성함
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 회원
CPSU-REGAN-W13S19G46
4 회원들
안내서 44개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 48
전체 시간: 839
