주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Fortune Motherboard Replacement
필요한 것
  1. LG Fortune Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Fortune Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
    댓글 쓰기
  2. LG Fortune Motherboard Replacement: 2 단계, 이미지 2개 중 1개 LG Fortune Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
    댓글 쓰기
  3. LG Fortune Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 1개 LG Fortune Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 2개 LG Fortune Motherboard Replacement, Motherboard: 3 단계, 이미지 3개 중 3개
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
    댓글 쓰기
  4. LG Fortune Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Place a spudger or an opening tool under the edge of the video card press connector and pry straight up to disconnect it from the motherboard.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
    댓글 쓰기
  5. LG Fortune Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
    댓글 쓰기
  6. LG Fortune Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
    댓글 쓰기
  7. LG Fortune Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Cori Johnson
회원 가입일: 04/08/19
537 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 51
전체 시간: 980
