주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Control Panel Replacement
필요한 것
  1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    댓글 쓰기
  2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    댓글 쓰기
  3. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
    댓글 쓰기
  4. LG Front Load Washing Machine Control Panel Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Control Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    댓글 쓰기
  5. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: 5 단계, 이미지 2개 중 2개
    • Pull the detergent drawer away from the chassis as far as it will go.
    댓글 쓰기
  6. LG Front Load Washing Machine Control Panel Replacement: 6 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement: 6 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement: 6 단계, 이미지 3개 중 3개
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    댓글 쓰기
  7. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: 7 단계, 이미지 3개 중 3개
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    댓글 쓰기
  8. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 8 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: 8 단계, 이미지 2개 중 2개
    • Remove the screw(s) securing the control panel.
    댓글 쓰기
  9. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: 9 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the detergent dispenser.
    댓글 쓰기
  10. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: 10 단계, 이미지 3개 중 3개
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    댓글 쓰기
  11. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: 11 단계, 이미지 3개 중 3개
    • Remove the control panel, making sure to thread any cables through the chassis.
    댓글 쓰기
  12. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel board: 12 단계, 이미지 1개 중 1개
    • Flip the control panel over.
    • Remove the screw(s) securing the control panel board.
    댓글 쓰기
  13. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel board: 13 단계, 이미지 3개 중 3개
    • Pull the control panel board out of its slot and remove it.
    댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
39,920 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,572개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 67
지난 30일: 209
전체 시간: 5,319
