주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Door Latch Replacement
필요한 것
    1. LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      댓글 쓰기
    1. LG Front Load Washing Machine Door Latch Replacement, Open the door: 2 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Open the door: 2 단계, 이미지 2개 중 2개
      • Open the front door completely.
      댓글 쓰기
    2. LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 3 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 3 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Door Latch Replacement, Remove the boot ring: 3 단계, 이미지 3개 중 3개
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      댓글 쓰기
    3. LG Front Load Washing Machine Door Latch Replacement: 4 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Door Latch Replacement: 4 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Door Latch Replacement: 4 단계, 이미지 3개 중 3개
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      댓글 쓰기
    4. LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 5 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 5 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Door Latch Replacement, Disconnect the boot: 5 단계, 이미지 3개 중 3개
      • Use your fingers to pull the boot off its lip in the front panel.
      댓글 쓰기
    5. LG Front Load Washing Machine Door Latch Replacement: 6 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Door Latch Replacement: 6 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Door Latch Replacement: 6 단계, 이미지 3개 중 3개
      • Work your fingers around the boot's perimeter until it's completely separated from the panel.
      댓글 쓰기
    6. LG Front Load Washing Machine Door Latch Replacement: 7 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Door Latch Replacement: 7 단계, 이미지 2개 중 2개
      • Use your hands to fold the boot into the drum.
      댓글 쓰기
    7. LG Front Load Washing Machine Door Latch Replacement, Unfasten the door latch: 8 단계, 이미지 1개 중 1개
      • Remove the screw(s) securing the door latch.
      댓글 쓰기
    8. LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 9 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 9 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Door Latch Replacement, Expose the door latch: 9 단계, 이미지 3개 중 3개
      • Reach between the boot and the chassis to grip the door latch.
      • Pull the door latch out of its slot in the chassis to expose it.
      • Don't try to fully remove the door latch yet. It's still connected to a cable harness.
      댓글 쓰기
    9. LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: 10 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Door Latch Replacement, Remove the door latch: 10 단계, 이미지 2개 중 2개
      • Disconnect the cable harness from the door latch.
      • Always grip cables by their connectors and not the wires themselves.
      • Remove the door latch.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,177 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 61,650개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 84
지난 30일: 372
전체 시간: 11,147
