주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Inlet Valve Assembly Replacement
필요한 것
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      댓글 쓰기
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      댓글 쓰기
    2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
      • Slide the top panel towards the rear of the device to disconnect its clips.
      댓글 쓰기
    3. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 4 단계, 이미지 2개 중 2개
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      댓글 쓰기
    1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 3개
      • To prevent confusion, label each valve and its corresponding hose.
      • You can use masking tape or mark the components themselves.
      • Repeat the labelling procedure for each valve and its corresponding connector.
      댓글 쓰기
    2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 3개
      • Disconnect the connectors from the inlet valve.
      • Always grip cables by their connectors and not the wires themselves.
      댓글 쓰기
    3. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 7 단계, 이미지 1개 중 1개
      • Place a dry rag under the inlet valve to soak up any lingering water.
      댓글 쓰기
    4. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 3개
      • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
      댓글 쓰기
    5. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 9 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 9 단계, 이미지 2개 중 2개
      • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
      댓글 쓰기
    6. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 10 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
      댓글 쓰기
    7. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 11 단계, 이미지 1개 중 1개
      • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
      댓글 쓰기
    8. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 3개
      • If your replacement part comes with filters pre-installed, skip this step.
      • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
      • Remove the filters.
      댓글 쓰기
    9. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: 13 단계, 이미지 1개 중 1개
      • Remove the screws securing the inlet valve assembly.
      댓글 쓰기
    10. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 3개
      • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,168 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 41,138개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 86
지난 30일: 272
전체 시간: 6,931
