주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Rotor Replacement
필요한 것
    1. LG Front Load Washing Machine Rotor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      댓글 쓰기
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Rotor Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
      • Remove the screw(s) securing the rear panel.
      댓글 쓰기
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Rotor Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
      • Unclip the rear panel from the chassis.
      댓글 쓰기
    3. LG Front Load Washing Machine Rotor Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the rear panel.
      댓글 쓰기
    1. LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 2개
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      댓글 쓰기
    2. LG Front Load Washing Machine Rotor Replacement, Remove the rotor: 6 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Replacement, Remove the rotor: 6 단계, 이미지 2개 중 2개
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
40,177 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 61,573개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 23
지난 30일: 107
전체 시간: 2,371
