주요 콘텐츠로 건너뛰기
LG G Watch R Motherboard Replacement
필요한 것
  1. LG G Watch R Motherboard Replacement, Back Case: 1 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
    So i bought a torx t5…but it is tooo big. It must br torx t4
    Jetze Kooistra - 답글
    I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
    I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
    What should I do? (Can anything be done?)
    John Maher - 답글
    Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
    Andrew L rambeaut -
    Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
    Ernst Kranke - 답글
  2. LG G Watch R Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
    Where do I buy the parts? I already have your tools.
    Marco Roman - 답글
  5. LG G Watch R Motherboard Replacement: 5 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
    Add colored markup to indicate location of the 3 screws.
    Patty Remmell - 답글
    I felt like my #00 driver fit slightly better for these screws, but it probably depends on which toolkit or bit set you have.
    J Suo - 답글
  6. LG G Watch R Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개를 작성함
댓글 3개
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - 답글
Where do I buy a replacement motherboard from??
Brandon Reznik - 답글
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 3,280
