도구
부품
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Lift the back cover to release the rest of the plastic clips and remove it.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
다른 21명이 해당 안내서를 완성하였습니다.
