주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G3 Front Facing Camera Replacement
필요한 것
  1. LG G3 Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    댓글 쓰기
  2. LG G3 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    댓글 쓰기
  3. LG G3 Front Facing Camera Replacement, Battery: 3 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    댓글 쓰기
  4. LG G3 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the battery out of its recess and remove it.
    댓글 쓰기
  5. LG G3 Front Facing Camera Replacement, Loudspeaker: 5 단계, 이미지 1개 중 1개
    • Remove the four Phillips #00 screws (4 mm length).
    댓글 쓰기
  6. LG G3 Front Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    댓글 쓰기
  7. LG G3 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 LG G3 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 LG G3 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    댓글 쓰기
  8. LG G3 Front Facing Camera Replacement, Motherboard Cover Assembly: 8 단계, 이미지 1개 중 1개
    • Remove the eight Phillips #00 screws (4 mm length).
    댓글 쓰기
  9. LG G3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 1개 LG G3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 2개 LG G3 Front Facing Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    댓글 쓰기
  10. LG G3 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 1개 LG G3 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 2개 LG G3 Front Facing Camera Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    댓글 쓰기
  11. LG G3 Front Facing Camera Replacement, Front Facing Camera: 11 단계, 이미지 1개 중 1개
    • Check to see that the ribbon cable is connected properly. If it was not, connect it and see if the front-facing camera now functions as intended. Otherwise, proceed
    • Take the plastic opening tool and gently wedge it under where the ribbon cable is connected
    • Gently lift up to disconnect the ribbon cable
    댓글 쓰기
  12. LG G3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 1개 LG G3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 2개 LG G3 Front Facing Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Repeat the same process for the other 3 ribbon cables connected to the motherboard
    댓글 쓰기
  13. LG G3 Front Facing Camera Replacement: 13 단계, 이미지 2개 중 1개 LG G3 Front Facing Camera Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the motherboard by lifting gently
    • Take care not to damage the ribbon cables if the other components are functional. Damaging them may result in other components not working
    댓글 쓰기
  14. LG G3 Front Facing Camera Replacement: 14 단계, 이미지 1개 중 1개
    • Take the plastic opening tool and remove the front-facing camera by wedging it into the sides and under the ribbon cable and lifting up
    • The front-facing camera is kept in place with an adhesive, so it may take some time and effort to get it out. Depending on how much force you are using, it may also be launched across the room
    댓글 쓰기
  15. LG G3 Front Facing Camera Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the old front-facing camera
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Naoto
회원 가입일: 10/16/14
4,763 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-3, Duarte Fall 2014 UMass Dartmouth, Team 1-3, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G3
4 회원들
안내서 16개를 작성함
3가이드 댓글
Naoto,
Thank you for the detailed guide it was very satisfying to repair this on my own.
please note: Image # 10 through me off for a few moments, until I realized it it was posted in mirror image mode.
For any one wanting to try this fix, I say “Go For It”
Also good to note: on my LG G3 . Once the back cover was removed, the inside back plate, comes apart in two sections the bottom 1/3 ( starting at the USB Charging port) is the first section that came apart.
Then the top section (starting beside the mid section of the battery housing) comes off easily.
Once completely removed, it was very easy to spot that the front facing camera ribbon connector just needed to be reset.
My phone feels brand new again :)
Again thank you
The Fix it Dude ,Fabian
The Fix Itdude - 답글 공유
how can I fix the wifi 5g? I loss the 5g signal after reflow. please point out the position of the 5g IC and show the picture. thank you very much
wing lam - 답글 공유
Yes since I have had my LG G3 it's been through alot considering it's now 2018 and it still has the performance needed and still more then alot of phones out there while being like 5 years old.
The biggest issue I have noticed and read about was overheating, in my mind caused by placing the CPU & GPU processors back to back. Luckily many people have come up with simple ways to help this. One in which I used was creating a more robust Heatsink, with just the use of alluminum from a tin can. Which worked great for me. Ya amazingly before I had done this I was seeing temps of up to 90°C which is liysuper high. It surprised me with such a great phone that they missed such an easy design flaw or possibly never had the time to figure out a better way before the release date
Calder Munroe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 9,176
